08 Padel Shifter Install Troubleshooting
So i installed my padel shifters myself and when i went for the test drive my steering wheel was out of alignment with the vehicle. I go over the install again and re-align the steering wheel to the wheels which is now pretty close. So i was wondering does this take the whole car out of alignment or should i be alright? Infiniti wants $140 to put it on the machine but too me the car just drifts very little to the left. What do you think?
edit:
If its drifting a little left you should get the alignment checked anyway..it shouldn't do that on most roads.
Thanks. I rather put the money into infiniti changing all the fluids and belts at the 60k mileage. Im at 52k so better start going through the list. The kit i bought for my car was off of ebay which was orginal equipment.
Agreed with what others have said; if the wheel isn't straight when you're driving straight, then it's just that you put the wheel back in the wrong position and need to re-position it, BUT if the car just isn't tracking straight (irrespective of the steering wheel position) then that is totally separate from any issue you caused by the R&R of the steering wheel; you'd need to look at all the usual suspects for not tracking straight (alignment, wheel/tire damage, tire pressure, brake/bearing issues, etc.).
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Machine Head
Sep 4, 2015 07:22 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
