Hello everybody.
I am new to this forum just got out of my BMW E70 4.8 X5 and into '07 G35S Sedan 6MT
I am trying to get some wheels and dont want to spend a lot, so i was thinking of going with these:
I know they are replicas but I am fine with that.
the size i am offered is the following:
19x9.5 ET22
19x10.5 ET22
i currently do not have any springs, but thinking of going with EIBACH since its less drop and i have a lot of BUMPs to my house, so don't want to take 20 min just getting through my complex.
Can you guys please help and let me know if that is too aggerssive?
will i HAVE to get springs?
will i have to get camber setup as well?
what tire size should i get?
i was just trying to get a flush setup and maybe even a little aggressive, but i have this feeling is is too much....
if you have a pic of a sedan with same offsets in 19' wheels, please post as well...
i really appreciate your help in advance.
19x9.5 ET22
19x10.5 ET22
With those offsets and width the rear is gonna poke out quite a bit. You will have to run at least a 255 or 245 and more than -2.0 of camber.
The fronts will fit no problem.
yeah the rear will poke at just a little but you will be fine my friend is running those same wheels on a 2006 g sedan and he pokes a lil in the back
Quote:
yep Originally Posted by apexi957
Rear will poke out slightly, but you'll be fine.
hopefully, thank you !!!BTW, i love your set up, what specs are you running? wheels/tires/offset?
White looks great!!!
Quote:
Thanks Preson... do you think you can find me a pic of it? just want to see approximately how it will look before jumping the ship lolOriginally Posted by preston8o8
Thanks! I'm running a 19x10 +25R +30F with Falken 452 245/35/19 all around. I could run a 10mm spacer in the rear if i wanted toOriginally Posted by BimmerSF
yep
Quote:
I am not sure. But i got my fenders pulled.Originally Posted by OMG35S
Those are the same wheels and offsets/sizes?
Quote:
why'd you get them pulled? they're not even poking or look like they'd rub, you just have big tires.Originally Posted by bluedevils95
Quote:
Cool thanks!Originally Posted by apexi957
I've been snooping around and saw you trying those wheels on lol......
just hoping if i get mines +22 offset they won't look like these
Not trying to fit those in....
