Tire helppp
Old Jan 5, 2012 | 10:14 PM
narek330's Avatar
Tire helppp
OK I need a solid answer for this problem. I get the runaround and millions of different answers. For a 07 g35 sedan journey 225/55/17 tires if i go with 225/50/17 winter tires in the back will it cause a lot of problems? its a rwd .
Old Jan 5, 2012 | 10:27 PM
blnewt's Avatar
235/50/17 will be better, it's only 1.8% difference in diameter from the stock size. The 225/50s will be over 3% difference which can create VDC & ABS problems and your speedo will be off quite a bit.
Here's a good tire calculator.
http://www.1010tires.com/tiresizecalculator.asp
Old Jan 5, 2012 | 10:28 PM
narek330's Avatar
helped out alot thanks for thatt
Old Jan 5, 2012 | 10:29 PM
str3zz's Avatar
Use google and voila you find this
http://www.discounttiredirect.com/di...foTireMath.jsp
Put current tire then put desire tire size click on calculate and see how much a different
Personal opinion I wouldn't
Old Jan 6, 2012 | 12:28 AM
vqsmile's Avatar
Even at 1.8% difference, you'll probably notice the VDC is a little bit more sensitive; triggering earlier and more easily. Not any big deal, but probably noticeable. If you want to keep it absolutely as close as possible, you can also consider a set of 245/50-17 which will keep the deviation to about -0.4% (same amount as the difference in factory staggered wheel sets). Of course, obviously you can go with same size tires on all four wheels too, but that's seems excessive.
Old Jan 6, 2012 | 10:28 AM
nineiron's Avatar
i'm running 215/55/17 winter tire setup (all-around) on my '07 G35S. seems to be fine.
but now i'm wondering if a different size would be more suitable...
Old Jan 6, 2012 | 11:21 AM
vqsmile's Avatar
^^ What's 'less than' suitable about what you've already got? You're a tad shorter in diameter (1.6%), but with the same size all around you'll have zero issue with vdc. Are you just wanting to run a wider tire?
Old Jan 6, 2012 | 01:43 PM
nineiron's Avatar
nope. just thought that i had an incorrect setup based on what ppl have been posting. thanks for the reassurance!
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
