g35x brake and tire question
Old Jan 14, 2012 | 12:47 AM
woostar88's Avatar
I have 07 g35x.
my front brakes and all four tires are overdue... im not sure which one to go with..
any suggestions? I don't want to break a bank but it will be good run for my money.
thank!
Old Jan 14, 2012 | 01:41 PM
mathnerd88's Avatar
Infiniti OEM pads and rotors suck...they warp pretty fast, and even after resurfacing, they warp even faster.
I got Hawk Performance Ceramic pads and Centric Premium rotors and they stop better than OEM and cost a lot less than getting OEM parts. I didn't want semi-metallics since they are a little bit harsher on the rotors. Plus, the wear seems pretty good and there is no noise or brake fade. One time I had to do an emergency brake because the car in front of me slammed his brakes and my car stopped really confidently without tire squeal. I checked the rotor condition afterwards and there is no scoring or pitting on them.
I recommend getting Hawk brand brake pads.
http://www.hawkperformance.com/performance/
If you want better braking performance, get the Hawk HPS pads and Centric Premium rotors. You'll run the risk that the brakes may squeal. Semi-metallics tend to be a little more noisy.
I got the brake pads and rotors from Amazon.com and total came out to be $380 for all 4 rotors and brake pads. Installation at a local shop was an additional $220 so I spent around $600 for replacing all the brake pads and rotors, which was much cheaper than what the dealer wanted or Firestone- (over $1000 for crappier rotors/brake pads.)
If you just wanted a brake pad change, then it would be much cheaper. However, I recommend getting new rotors because the stock OEM rotors pulsate pretty badly and quickly. Plus, you'll need to resurface your old rotors anyways for a brake pad change and it's not worth it.
As for tires, if you want luxury touring performance but not ultra high racing performance, I would recommend the Michelin Primacy MXM4 tires. They are better than the Bridgestone Turanza Serenity according to TireRack and they have it at a good price at Costco. Personally, I have the Goodyear Eagle GT's and they perform pretty well too, and are much cheaper. Since I live in the Boston area, I buy tires with rim protectors so I don't scratch up the rims during parallel parking. Michelin Primacy MXM4 and Bridgestone Turanza Serenity both have rim protectors also.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=138
Hope this helps!
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
