Do not pass Go...
Old Jan 28, 2012 | 12:37 AM
bluedevils95's Avatar
Oh ok! Glad you got it fixed. Now you can enjoy your G again
Old Jan 28, 2012 | 12:40 AM
faiz23's Avatar
350Z (Z33)
2005 – 2006 284B7-CD01A
2004 284B7-AQ01B
2003 284B7-AL51B
http://www.titantalk.com/forums/atta...ntb04-111b.pdf
Old Jan 29, 2012 | 04:45 AM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by Wannabe6MT
Whats an IPDM?
You've owned a G long enough, you should be embarrassed you asked that question.
Old Jan 29, 2012 | 12:03 PM
salvador312's Avatar
Whats an IPDM?
Is the big black box that goes right under the battery compartment!!
Here a picture of it outside! With the lid off!
Old Jan 29, 2012 | 12:51 PM
faiz23's Avatar
Driving around with no under shield, no battery cover, no fender liner, just to gO low n slow is crazy... Just imagine all the electrical components and metal structure that is exposed to water, snow, salt, debris and more. All that will accelerate the point of failure n lead to large shop bills and dents in wallets
Old Jan 29, 2012 | 12:54 PM
vqsmile's Avatar
Originally Posted by nadatoy
.. At this point, he notices a large amount of water draining out of my car onto the floor and seems to have collected below the battery because the drain down below the battery box is plugged with pine needles. He then removes all the items needed to get to the drain and when he got to the IPDM, it turns out to be completely waterlogged. When the drain plugged up, it actually filled the entire battery compartment up with water high enough to get into the unit. ....
It was an aftermarket warranty.....This is the first G35 they had seen with this problem, but I was able to find a few instances of it with other folks by searching the net. It will probably never happen again after I get a replacement battery cover as it has been missing since I first bought the car and obviously could allow debris into the area.
So it seems as though there was no "crappy engineering to be expected from Nissan" after all faiz, just a bit of operator negligence by not keeping the cover in place for extended periods of time. (no offense OP, just sayin)
Originally Posted by faiz23
Another friend of mine had to get IPDM replaced and this is a common issue on Nissan and infiniti. Crappy engineering (TO BE EXPECTED FROM NISSAN) that leads to a $1200 repair bill....
Time and time again, it's been proven that no amount of good engineering can overcome plain old negligence/ignorance, but just like I said, haters gonna hate.
Old Jan 29, 2012 | 12:57 PM
vqsmile's Avatar
haha, yeah . . . so I guess YOU DO recognize perhaps there;s more to the story than crappy engineering
Old Jan 29, 2012 | 04:11 PM
nadatoy's Avatar
Old Jan 29, 2012 | 04:27 PM
faiz23's Avatar
350Z (Z33)
2004 284B7-AQ01B
2003 284B7-AL51B
IPDM failing due to operator error is just plain stupid and can be pointed to the fact it was not left in OEM form and modified somehow by the user. Now please explain why Nissan fancy engineering leads to IPDM failing for all these vehicles in stock form. Do I need to bring back the topic on window motors, AC radio controls, Rev-up motors, manual tranny cd001-008, compression rod bushing...do i need to go on.
2002 – 2006 Altima (L31)
2004 – 2006 Maxima (A34
2004 – 2006 Quest (V42)
2003 – 2006 Murano (Z50)
2003 – 2006 350Z (Z33)
2004 – 2006 Titan (A60)
2004 – 2006 Armada (TA60
2005 – 2006 Pathfinder (R5
2005 – 2006 Xterra (N50)
2005 – 2006 Frontier (D40)
Old Jan 29, 2012 | 05:31 PM
vqsmile's Avatar
^^ Well, not a single V36 in that list. They have been out for 5 years now
Old Jan 29, 2012 | 06:04 PM
G3Sx's Avatar
To keep things fair though, we need to compare the quantity of similar TSB's released by other manufacturers. I'm certain that Nissan's amount of TSB's does not exceed those of other brands.
But I will agree that the mesh part of the windshield cowl, which sits above the battery lets rain water through into the battery compartment as I find drops of water between the battery terminals after each drive in the rain. I'm guessing it is designed for venting the battery compartment since the factory battery does release gasses as part of its normal charge/discharge cycles. I'm closing mine off so no water can get in at all since I run a sealed XS Power battery.
Old Jan 30, 2012 | 03:04 PM
G35XX's Avatar
So the battery cover actually serves a purpose??? Who would've thought!!!
Old Jan 30, 2012 | 03:16 PM
funkydrummer's Avatar
Seems like all signs point to negligence to me. It sucks, but you gotta keep up with the leaves and neettles in the cowl, under hood, doors and trunk.
Old Jan 31, 2012 | 08:48 AM
07-G35-MT/S's Avatar
Glad for you that they fixed it.
Old Feb 11, 2012 | 12:37 PM
  #30
luger303's Avatar
FAIZ23
Lol, we are all aware of the issues.
Just pretend we don't though. Tell us more. At this point we all care tremendously what you have to say.
What else do you think about nissan. We really want to know.
seagrasser
May 3, 2022 09:43 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
TNRocker
Sep 21, 2015 08:36 AM
