Grounding Kit Vs. Shift Kit
Old Mar 8, 2012 | 12:33 AM
kool_yaar's Avatar
my friend dropped the pan on his 05 G and measured around 5qts... best way is to measure what comes out and refill with same amount and then check level with proper procedure.
Old Mar 8, 2012 | 12:36 AM
chink-ah-saur's Avatar
Hm mine was 7 1/2
Old Mar 8, 2012 | 12:42 AM
GAU-8's Avatar
Mine's an '06 as well. I didn't measure what came out. Rookie move. I did fill it gradually and warm it up and continue until it measured full. I think I only put 5 or 6 in.
Old Mar 8, 2012 | 12:46 AM
Its weird if I shift around 3 it still takes up to 4k to drop in gear but if I mash on it it shift right away
Old Mar 8, 2012 | 07:56 AM
aquabat0587's Avatar
I bought the transgo kit and took it to a shop and I ended backing out because I didn't realize that they will be drilling through the valve body to make the kit fit. This scared me as it was irreversible and I wasn't sure whether I would like the way it drove afterwards for everyday driving(I commuted 25 miles to work). I plan on getting the grounding kit soon though.
Old Mar 8, 2012 | 10:06 AM
bwalsh's Avatar
Just get the grounding kit if you have some extra cash laying around. Doesnt really do much but boost your stereo a little. Dresses up engine bay a little and thats about it. Good luck/ look at stillens its not bad
Old Mar 8, 2012 | 11:27 AM
GAU-8's Avatar
All the drilling will be doing is opening already existing holes in the VB. It's to allow a bit more fluid flow. Like going from a 7/64 hole to a 1/8 hole. It does seem scary at first, but again, I did this work with a buddy and had no problems at all. The commute would be fine. Normal driving doesn't reveal the harsh shifting. It's when you get on it that it shifts firm. Just for info, the 1-2 shift still lags for a moment. It's designed to do that because of the low gearing. I'm on a 3.5VLSD and a shift kit, so it's that much more fun!
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Machine Head
Sep 4, 2015 07:22 PM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
linedr89
Aug 17, 2015 05:11 PM
