Question for those who painted their headlights
Old Feb 8, 2012 | 02:19 PM
soundmike's Avatar
Did y'all put them back together after the paint dried to touch, or paint cured?
I'm thinking of using high heat paint. It can be handled within a few hours, but it doesn't cure for 5-7 days and i don't want it emitting too much gas with the headlights already sealed.
Worst-case, i could use regular paint (not high heat), but i'm just not sure how that'll work as hot as it gets round here sometimes.
Thanks, folks.
Old Feb 8, 2012 | 02:58 PM
mishmosh's Avatar
Wow...5-7 days? I let mine dry 24 hours and thought that was good enough. Not sure what the directions on my flat black said but I thought it was enough.
Old Feb 8, 2012 | 03:02 PM
SxExCx's Avatar
always let them dry completely to avoid moisture accumulation on the lens.
Old Feb 8, 2012 | 03:58 PM
soundmike's Avatar
Just for the high heat stuff. Which paint did you use? Did you have any problems of extra gassing causing the lens to haze?
I figured as much -- so does that mean dry to touch after several hours is okay, or do i wait for the full curing time of several days?
Thanks, guys.
Old Feb 8, 2012 | 04:11 PM
mishmosh's Avatar
I used Dupli flat black on top of primer. No haze to lens at all. I even used additional butyl rubber sealant and let that dry for a few additional hours. I think it has been a year now and the paint looks like it did when I first paint it. I feel like the headlights are one of the most satisfying mods I have done to the car.
Old Feb 8, 2012 | 07:02 PM
soundmike's Avatar
Thank you. I just measured the temps on the headlights after 20 minutes of driving with all lamps on (including fogs) and i highly doubt temps will rise beyond any regular spray paint thermal limits, i think i'll follow your route.
Old Feb 12, 2012 | 06:58 PM
luger303's Avatar
I actually used black engine paint for mine. worked great and I onlyl let it set for a few hours before reassembly.
Old Feb 13, 2012 | 02:22 AM
GXXXV X's Avatar
I used high heat black gloss and let it dry to the touch for a few hours... as for moisture that is not a concern because we have open headlight housing's anyway so if you see moisture it will always disappear within a few hours
Old Feb 13, 2012 | 09:20 AM
soundmike's Avatar
Thanks folks.
Old Feb 13, 2012 | 08:21 PM
saywat?'s Avatar
dry to the touch for me. i didnt have the convenience of waiting hours. i needed my car back on the road . no issues here.
Old Feb 14, 2012 | 02:40 AM
apexi957's Avatar
I actually just waited 20 or 30 minutes for it to dry and just resealed everything. Just dont reseal it with silicone..
Old Feb 14, 2012 | 07:23 AM
soundmike's Avatar
It's settled then, just ample drying time.
What did y'all use to reseal? I've opened up headlights from my old Maxima, not to paint, but when i resealed i just used whatever was still on there. Never had condensation issues with it.
On the G, i might run some butyl all around the perimeter after it's back together.
Thanks again!
jsimonk
Dec 22, 2023 03:49 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Th611
Oct 27, 2015 03:48 PM
rsingerG35
Aug 18, 2015 10:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
