G35 Sport Akebono Upgrade
Old Feb 13, 2012 | 12:02 PM
Jeff92se's Avatar
Red Card Crew
26lbs per front rotor for the Akebonos is just too heavy for the performance. IMHO
Old Feb 13, 2012 | 12:25 PM
vqsmile's Avatar
Originally Posted by Q8y_drifter
May have been due to uneven pad deposits, which is not uncommon even with the Akebonos.
Here's a comprehensive article I've bookmarked on the issue:
http://www.powerbrake.co.za/download..._01_judder.pdf
Old Feb 13, 2012 | 01:17 PM
rvanderwerf's Avatar
you can get the 2 piece rotors from racing brake, but I think they're over 400 EACH
Old Feb 13, 2012 | 01:21 PM
vqsmile's Avatar
Agreed, and then, to make it even worse, you typically add for heavier wheels and tires required to fit over them.
Old Feb 13, 2012 | 01:30 PM
did you lube all the parts real good with brake grease when you replaced the pads last time? they shouldn't be sweaking at all...
Old Feb 13, 2012 | 01:57 PM
soundmike's Avatar
Solved that problem.
Old Feb 13, 2012 | 02:22 PM
vqsmile's Avatar
Yes, you did!
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
