Warm air out of vents, then cold air at same temperature setting
Old Feb 26, 2016 | 02:35 PM
RemmyZero's Avatar
Well i'm losing coolant from the overflow tank because it's cracked and needs to be repaired again so when the radiator inventory expands I inevitably lose a little.
I did jack the car up and bleed it although I may invest in a lisle funnel anyway. I don't believe this is trapped air because the heat will work like a champ for the first 10-15 minutes of my ride then begin to taper off to a sad lukewarm state. It's not the typical "my car is hot when I am moving and cold when I stop" issue.
champppy
Mar 31, 2020 12:25 PM
Greg Huston
Sep 25, 2016 11:36 PM
MR M37s
Oct 30, 2015 08:32 AM
underworld
Aug 6, 2015 01:36 PM
paniaguag35
Jul 29, 2015 12:05 PM
