Car Vibrating While Idle
Old Mar 3, 2012 | 07:54 PM
Stevins's Avatar
I have a MY08 Sedan and every so often my car will start to shake/vibrate while in idle, mostly when the car is in park. I've cleaned the TB and taken it to the dealer who says "everything is fine" and of course the car didn't vibrate while they had it. I was wondering if I should clean the MAF sensor. I searched these forums and couldnt find much about it. Does anyone know how to clean the MAF sensor and where it is located? Thanks in advance.
Old Mar 3, 2012 | 09:40 PM
Anton_Chigurh's Avatar
Motor mounts..check them
Old Mar 4, 2012 | 12:24 AM
kool_yaar's Avatar
MAFs are super easy to clean, get crc maf sensor cleaner and liberally spray the sensors inside out as stated on the directions of the bottle, i do this when i clean my TB without any issues but still just as a common disclaimer... do this at your own risk!
Old Mar 4, 2012 | 12:58 AM
lsmooth81's Avatar
I agree with Anton, check your motor mount. I had the same problem with my honda at idle only. I also noticed that it would happen after the engine idles for a while (over 5 minutes idling) Good luck with this.
Old Mar 4, 2012 | 09:45 AM
Stevins's Avatar
My dealer told me that a motor mount is either bad or good and that it would happen all the time if it was bad, is that true?
Where is the MAF sensor?
Thanks for the responses
Old Mar 4, 2012 | 09:57 AM
Shanes_G's Avatar
the maf sensor is right above the air box. it has the wire sticking out of it.
Old Mar 4, 2012 | 10:12 AM
herrschaft's Avatar
I never dealt with a bad motor mount yet but I doubt there would be any vibration when the engine is under load. Just pop the hood and observe how much the engine moves when you step on the gas.
Old Mar 4, 2012 | 02:17 PM
CFitz's Avatar
My car also vibrates a little when I'm at a standstill (like at a light) but its when the engine hits a certain RPM range, typically around 600<x<800 Rpm
EDIT: It occurs at 850RPM, I looked at the gauge this time
Old Mar 4, 2012 | 05:31 PM
vqsmile's Avatar
Hmm . . . I'm not feelin this whole motor mount theory. It seems like it would not be intermittent if it were a bad mount. We need a bit more information from the OP though, like are are the rpms fluctuating when it does the vibration. I'm thinking this is just a "shiver" caused by the engine rpms dropping and then catching again, which could happen regardless of motor mount conditions. Besides that, I can't recall hearing folks reporting bad motor mounts on these, so it seems somewhat against the odds. If the idle fluctuates, then I'd just be looking for what may be causing that.
.02
Old Mar 4, 2012 | 06:59 PM
lsmooth81's Avatar
That is not exactly true. Bad motor mount would not always be felt under load.
.02
I agree that is rare to hear bad motor mounts on our G, it does not mean that it could not be the problem. Like I responded to OP a bad motor mount does not vibrate as violently or when under load. I had a similar problem on a different car the car would not vibrate while driving, but as soon as I stop at a light it would vibrate, as soon as I start driving again it would go away.
I do agree with you that OP needs to give us more info to assist in troubleshooting, but I would not disregard the motor mount just becuase it is intermittent. If his RPM are fluctuating then I would have to say that the motor mount is not the problem.
Old Mar 4, 2012 | 09:11 PM
Stevins's Avatar
The RPMs do not seem to fluctuate, the car just vibrates when in Park, but it hasn't happened in a few weeks now. I'm just concerned because my warranty will be up very soon.
Old Mar 4, 2012 | 09:16 PM
lsmooth81's Avatar
Does not sound like your motor mount or MAF sensor.
Old Mar 4, 2012 | 11:52 PM
pattyballs's Avatar
I have a similar problem but only when in drive. It started out just a slight vibration and it is starting to get worse. It is mainly noticed when waiting at stop lights. Pretty heavy shaking and the rpm's are around 850. Will check out tomorrow and see if there is excessive motor movement when revved.
Old Mar 5, 2012 | 12:20 AM
RedBaronK's Avatar
Honda cars are notorious POSes when it comes to bad motormounts...
Usually vibrations only at idle are a sign of a mount going bad.. but for a Nissan and so soon seems unlikely
Old Mar 5, 2012 | 02:36 AM
Paneraiguy's Avatar
I had the same issue with my 08'. However, my idle was low (around 600). After cleaning the TBs and the MAF's the issue never went away.
I took it to the dealer and thier solution as they told me was to reset the idle portion on the ECU which actually worked. It still has a very subtle vibration every so often at a stoplight but thier solution stopped the annoying (message chair) vibration I was getting originally.
