PICS! Just installed 370Z springs and 19's on 08x!!
Hey guys,
Just got the 370Z springs installed on the front of the car yesterday. Thanks for everyone that helped me while researching this option for lowering the X. I didn't want a huge drop and this delivered that result. Only thing is, my mechanic and I talked and decided NOT to cut the rear shock mounts at this time, because we both liked the raked look of the car (and I hate a car that appears to be lower in the rear than the front). So we'll wait and see how much, if at all, the front springs settle and then go from there. So far, I'm measuring approximately 1/2" drop in the front, which is a little less than what I read (7/8" drop)...so maybe they will settle some more? Anyways, here are the pics.
Obviously the first two are with the listed work done, including the 19 x 8.5" (+35) MRR HR2's (thanks Charles, B2AutoDesigns), with 245/40/19's Sumitomo HTRZ III on all four corners. The second two pics are of stock ride height/wheels.
I like it a lot. Awesome, relatively cheap mod. And even more importantly, I love the wheels
Thanks Charles (B2AutoDesigns)!
Let me know what you guys think.
Matt
Oh, I didn't get it aligned yet to check out camber adjustment....got the alignment planned for Monday.
Thanks Charles (B2AutoDesigns)!Let me know what you guys think.
Matt
Basically, I didn't want to spend money so I can bash up my front diff with a bad pothole or be helping the local road crews plow snow with my front bumper in the winter.
I think its a nice sublte lowering job,,, its something i might do in the future,, since i LOVE the look of mine,, but don't really like the ride on the roads we have around here.... I am on Eibach's btw...
Looks pretty good. I was one of the guys that did the same a few years ago when I had my X.
The front should settle to a 7/8" drop...mine did.
Something that non X owners may not know/consider is that the front differential is very close to the ground so lowering is something I wouldn't do to much on the AWD if you live in a very snowy winter climate and have bad roads. Like PA.
Also, if you are interested, I have a set of barely used rear upper spring mounts that you can have. They have been just sitting in my garage for a couple years. You cover the shipping and they are yours. This way you can cut a pair and switch back if you don't like it. The rears are very easy compared to the front.
Looks good, close to stock but a good, even height match between the front and rear. I wonder if I'd get similar results with the 18" sport wheels on my 08x. Hmmm..
The wheels won't make any difference. The tires on the 17" and 18" rims have the same ~84" circumference.
The height match he has will be gone in a couple of weeks when the front settles. To keep it level you need to shave the rear upper coil spring mounts at least 5/8".
On a side note, I actually like the wheels more than I even thought I would!
Looks great! unfortunately it usually takes an awd-owner's eyes to appreciate the subtle drop
I've got a pair of front 370z springs myself... hopefully i'll get around to having them installed some day!
it think it looks much better. Post more pics later on so we can see it settled.
SEXY WHEELS!!!!!!! DAMN!!!!!!!!!!!!!!!
lol, I have the same wheels but staggered .19x8.5Front and 19x9.5Rear! Take another picture of the front. I want to see how meety the tires looks! I got 245/35 in the Front and I want to go 245/40. Closer to stock circumference! (Of course I'll change the rear to 275/35)
Another thing to consider. The X already has some understeer from the factory. If you haven't already noticed, you will shortly that you have just contributed to the understeer even more with the new spring/mount set up. Time to upgrade your rear sway if you want to properly correct that.
Post some pics after awhile so everyone can see the set up after settling has occured. Guess some of the "S" guys just don't understand the need for a mild drop on our X's.
How long will it take to settle the entire way? I have an oil change coming up in another month or so, so I was planning on getting the rear shock mounts cut down at that time if need be.
And yep, I will definitely try to post more pics once it's settled the entire way and after the rear shock mount cut is done. Thanks again for the compliments, help, and suggestions.
my 370z springs were basically brand new since the owner upgraded his springs right when he got his car. I can't remember the exact time frame but I think it was a couple of weeks and I could tell a difference. Some it will depend on how new the springs are. Hopefully that helps, maybe someone else can chime in, just don't have an exact amount of time.
