What bushings are these? They looked cracked
Under the car today checking stuff and found this.
Both of these bushings look to have a crack in them
It's this bushing
Is that the control arm bushing?
I don't know if you can tell by the photos as they were take with my phone. You can see the crack/shadow in the top one. Both sids of car have this exact same crack. These bushing should have no cracks in them correct?
It's this bushing
problem is i don't have a good camera ATM
The weather probably raped them. Or too much powerslides lol. Does snow falls where you are located? But if you don't hear any knock going over imperfections on the road don't bother it unless you see it get a lot worse.
That first pic you can see that crack..but i just don't know if it's normal.. since both have it in same place..ill try to get better pics
Maybe that's why also when i hit a bump/bridge abutment, my wheel goes haywire over the bump
Car has always seem to hop over bumps on the highways as well as vibrate..hoe much are the bushings..big job to do?
I'm pretty sure you've been through your car thoroughly trying to figure out your issue but I figure I'd mention this anyways....my wife's car had a blown shock which was causing bouncing over expansion joints and bumps, it had gotten to the point of being outright dangerous. I would have never suspected the shocks were blown considering it only had 50k, PLUS a mechanic said they were fine, but sure enough when I replaced them one was pretty much frozen.
