2008 G35x - Do both headlights rotate?
Old Mar 31, 2012 | 01:59 PM
dbcaugust's Avatar
New to the Infiniti scene with the purchase of a used 2008 G35x. Drivers side headlight was replaced and noticed it is not rotating when the wheel is turned but the passenger side does. Are both lights supposed to rotate? Need to know before I bring it back to the dealership.
Old Mar 31, 2012 | 02:26 PM
J2S2M's Avatar
Only if you have the TECHNOLOGY packaged. You will get intelligent cruise control and adaptive headlights w/ this option.
Old Mar 31, 2012 | 02:51 PM
dbcaugust's Avatar
So why does the passenger side rotate and not the Drivers side? Is that spec?
Old Mar 31, 2012 | 02:52 PM
J2S2M's Avatar
They should both be adaptive to the turning radius. If only one side is working, I'd take it to the dealership and let them deal with it. It should be covered under warranty. GL
Old Mar 31, 2012 | 03:09 PM
Swagger_Jacker's Avatar
drivers headlight only works above 16 mph. passangers works as long as its in gear.
Old Mar 31, 2012 | 03:17 PM
dbcaugust's Avatar
Thanks for everyones replies... Swagger is correct. I found the same info on another site and validated it with this Youtube video. Mine does the same thing, at a stop and in drive only the passenger side swivels. I guess I have to go out and do 16 mph to see if the driver side works.
Old Mar 31, 2012 | 03:33 PM
try coming to a stop from over 16 and u should be able to see it work.
Old Apr 1, 2012 | 01:41 PM
matts08x's Avatar
LOL to the above video. Not about the fact that you posted it, but just the thought of someone taking the time to video that.....wow. hahaha
magnetism80
Feb 1, 2019 10:00 AM
gatorglaze
Sep 10, 2015 12:03 PM
NJ6MT
Sep 10, 2015 08:40 AM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
kevintandmd
Sep 3, 2015 06:41 PM
