Brake pad? OEM or aftermarket? Resurface the rotor?
Old Apr 19, 2012 | 08:03 PM
stockae92's Avatar
Its about time to repalce my rear brake pads?
Should I go OEM or aftermarket?
Do I have to resurface the rotor at the same time?
Old Apr 20, 2012 | 12:10 AM
Xmax's Avatar
I'd say go aftermarket, there are plenty of pads to go with, a few recomendations are akebonos, Hawk, Stoptechs. As far as rotors depending if they are the original rotors that came with the car or if they have already been replaced. Measure the thickness of the rotor if they are within spec and if there room to have it resurfaced. But if I were you I would just replace rotors and get some slotted ones.
Old Apr 20, 2012 | 12:15 AM
Greenlawnracing's Avatar
I need some pads as well. Lots of driving for work, but would like a mild performance upgrade. Recommendations and best place to buy?
Old Apr 20, 2012 | 12:38 AM
william747400's Avatar
Lots of options are available. I get mine from Tire Rack. They have a variety of pads and rotors to suit you and there are tons of reviews from people who have used that product before.
The stock pads tend to produce a lot of dust and has good initial bite.
Akebono ceramic pads are very quiet and produce almost no dust at all.
Hawk HPS pads are rated as having better stopping ability but they wear quick if you are hard on your brakes. In addition, they dust quite heavily and squeak under light braking.
For the rotors I would resurface them if it is still within spec mainly to clean off the layer of brake pad deposits and allow the new brake pads to properly bed themselves.
Old Apr 20, 2012 | 07:35 AM
AuAltima3.5's Avatar
My rule is: if the rotor is not scored or warped then I just clean it and install new pads.
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
