07+ Journey with 07+ Sport Sedan seats
I'm reaching out to anyone who has successfully swapped out their original journey seats with sport seats, specifically the driver's side. I realize the sport seat has the bolster bladders which fill up and deflate for the thighs and torso. Everything else appears to be the same, but I'm unsure about the wiring harnesses involved. In a perfect world, the sports driver seat would bolt in and hook up perfectly to my Journey and I would be able to inflate these bolsters. My journey was equipped with the wiring for the paddle shifters, so I installed those recently. Would love the same scenario to drop in the Sport's driver seat.
Any experience with this guys and gals?
I think the only difference between the seats is the extra wires for the bolsters which i think are connected through the wires that power the other parts of the seats. So the main connector that goes from the seats to the main body harness are probably the same. I too wanted to do this but its hard finding a good pair and with no blemishes or scraches on 'em.
I remember this was discussed quite a bit back a few years and a few did the swap. Do a search back as for as 07/08. There should be a couple threads about this. Good luck.
Btw, the sport seats also have a manual sliding thigh support.
EDIT: Found these
https://g35driver.com/forums/g35-sed...-possible.html
https://g35driver.com/forums/g35-sed...wap-seats.html
PM a couple of these guys. They can likely provide info on if the wiring is compatible.
EDIT: Found these
