using way too much gas
Old May 10, 2012 | 10:24 PM
willdogs's Avatar
You are a bit light on details my dude...
Year?
mileage?
Mods?
Last service performed?
Etc
Old May 10, 2012 | 10:28 PM
G420's Avatar
Year?
mileage?
Mods?
Etc
Year? 08 sedan
mileage? 40K
Mods? no mods bone stock
Last service performed? oil change at infiniti
Etc
Old May 10, 2012 | 11:36 PM
vqsmile's Avatar
Ignoring any mileage readout given by your car, what was the difference in the odometer readings between your fill-ups, and how many gallons of gasoline were added to fill the tank?
Old May 11, 2012 | 10:25 AM
rpm&my_G35's Avatar
Am I crazy (quite possible) or is G420 telling us that he drives 12 miles per day and has to refill, from being near empty, in 5 days?
That's just 60 miles per tank or about about 3.5mpg.
Old May 11, 2012 | 01:10 PM
vqsmile's Avatar
No, I think your math is correct there, but I don't really believe it is actually occurring. My guess is that there is simply an erroneous indication somewhere. Either the tank isn't being filled completely, the gauge is misreading, the neighbor is siphoning gas, etc. etc. If the car was actually running that poorly, it would be throwing codes all over the place. Based on his screen name, I'm still wondering if this is just a troll.
Old May 11, 2012 | 05:04 PM
G420's Avatar
yes this is what the problem is.....I dont see a leak anywhere but the car seems like it has more hp than before....did i get a free mod? or computer problem?
Old May 11, 2012 | 05:05 PM
G420's Avatar
why are you trying to flame me for my handle name? sounds like you should do the 420 and just chill out geez
Old May 11, 2012 | 05:10 PM
vqsmile's Avatar
Originally Posted by G420
...the car seems like it has more hp than before....did i get a free mod? ...
Oh wow, this just gets better and better.
Old May 11, 2012 | 05:13 PM
vqsmile's Avatar
If you are serious about solving whatever "problem" your car has, then you might just simply answer the questions that are asked (ie. posts # 3,4,5) from people trying to help you. Otherwise, given that your described symptoms are so completely over the top, it does become a very real possibility that you're trolling here. Sorry if that's not the case, but it does happen.
Old May 11, 2012 | 09:25 PM
RedBaronK's Avatar
Change the air filter for the engine... that actually helps alot
Old May 11, 2012 | 09:37 PM
vqsmile's Avatar
Those would have to be quite the filters to make a 15+mpg improvement.
Old May 11, 2012 | 09:44 PM
Anton_Chigurh's Avatar
rotate the tires..that should do it
Old May 11, 2012 | 10:31 PM
G420's Avatar
I think my throttle body is dirty also but i dont think my tb is the problem either....will dirty tb throw the cel light on?
Old May 12, 2012 | 12:00 AM
vqsmile's Avatar
Well, looks like you're obviously not serious about answering questions or facilitating any real problem solving here.
Smelling more like a troll in here all the time guys.
Old May 16, 2012 | 04:03 PM
  #30
mcmig's Avatar
I had the same issue, couldn't figure out what it was, my sparks plugs weren't due to be replaced according to the service manual, my mechanic recommended that I change them anyway, I replaced them with NGK Laser Iridium and that fixed my issue right away.
