Brake Question
Old Apr 28, 2012 | 11:46 AM
Stevins's Avatar
Brake Question
If my steering wheel vibrates when braking from high speeds, more than likely the rotors are warped and the pads are fine, correct? I had the TSB done for the brakes where they shaved the front rotors and replaced the front pads, last summer. Now its starting to shake again....
Old Apr 28, 2012 | 12:50 PM
soundmike's Avatar
It could also be from uneven pad deposit on the rotors.
Old Apr 28, 2012 | 01:58 PM
vqsmile's Avatar
Some suggested reading. Pay particular attention to references to cementite, as its formation usually signals a death spiral of the rotors.
http://www.brakeworld.co.uk/TB1%20-%...ED%20DISCS.pdf
http://www.stoptech.com/technical-su...nd-other-myths
http://www.ebcbrakes.com/troubleshooting.shtml
Old Apr 28, 2012 | 08:51 PM
surfjax87's Avatar
I just got my car back today from dealer after they machined the rotors a second time. Had it in at 11k miles and had tsb done, back in at 32k miles for the same vibration/judder. Only way to solve it is to go with better rotors and pads that won't leave deposits.
Old Apr 28, 2012 | 08:53 PM
surfjax87's Avatar
+1. The rotors themselves usually don't warp, they're still the same shape, but the pads are soft and leave deposits on the rotors, creating an uneven surface, hence the vibrations when braking.
Old Apr 29, 2012 | 12:11 AM
Stevins's Avatar
thanks
jsimonk
Dec 22, 2023 03:49 PM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
