07 g35 sedan catalytic converter question
Old May 10, 2012 | 04:38 PM
drcasper's Avatar
Hi guys .. here goes... the Catalytic converter right under the driver's seat is rattling pretty bad.. I took it to have it checked, and it looks like I will need to replace it. problem is, the OEM replacement is really expensive, and used ones here are hard to come by.
my question is.. does anyone know the best alternative for getting this CAT replaced? there are ton of aftermarket cats available for half the cost of just the one I need.
Please keep in mind I'm in Cali, and will eventually have to go trough a smog test.:/
I Basically need it to be as close to OEM as possible, without paying the retail on those things.
Thank you for your time
Old May 10, 2012 | 04:55 PM
RedBaronK's Avatar
I had the same issue on my 08 after only 53k. I read somewhere that u can drill into the cat and use a nail or a screw to "stabilize" and hold the cat in place from rattling. Can't quote me on te exact process, but u may want to do a search. Also, how many miles do u have? The emissions warranty is longer than the manufacturers.
Old May 10, 2012 | 05:17 PM
mishmosh's Avatar
Federal warranty on catalytic converters is up to 8yr/80,000 miles. Not sure if that has to be functional defect but you could try to hit your dealer up to replace it on warranty grounds.
Old May 10, 2012 | 06:01 PM
drcasper's Avatar
yikes :/ I wished I knew this 387 miles ago.. although.. they could always argue this was most likely due to the collision I recently had.
btw.. i crashed my car 2 months ago
I'm going to call them up just for kicks..
thanks for the advice.. I still think I need to look over some 3rd party alternative
Old Apr 30, 2016 | 09:34 PM
giorgios's Avatar
The service engine soon light turned on yesterday and went to the dealer to find out what the issue is. They told me my catalytic converter and midpipe is cracked. They gave me a quote of $3300 to get them replace. Are there catalytic converters that i can order that will be the same as stock but not as expensive?
I would get HFC but I am worried about passing inspection in NY.
My car is a 2008 G35XS.
Old Apr 30, 2016 | 09:47 PM
RedBaronK's Avatar
Are u sure it's actually the catalytic converter and not the oxygen sensors? I ask because my car has loose honey combs inside the catalytic converter so it rattles, but despite that it still does its job and I don't get any warning lights. It's just a nuisance. I can only guess that the mid pipe being cracked makes the exhaust leak and it's not being properly filtered by the cat, and the light is going off... Or the oxygen sensors are bad.
So, if it is indeed the mid pipe that's bad, even if ur cat is rattling u can fix the leaking mid pipe and still be fine. If the oxygen sensor is bad, then that needs replacing, not the cat... So this really depends on what the actual problem is...
1. Is it the cat that's bad, if so why? Is it rattling? Clogged?
2. Assuming the cat is actually fine, then my money is on the fact that it's not fully working since the leak in the mid pipe is preventing the cat from doing its job
3. The service light is actually caused by a bad oxygen sensor, and ur stupid crooked dealer is trying to screw u.
I would say go to another mechanic, preferably non dealer, and don't mention anything about what the dealer said and just have them give u their diagnosis... Hopefully a free one, and see if this mechanic comes to the same conclusion.
Or go to auto zone and use a OBDII or whatever it's called to can ur error code and see what the computer is telling u is broken and causing that light.
Not all problems should he fixed for 3k...a catalytic converter rattle like mine can just be ignored, it's totally functional just annoying. U first need an accurate diagnosis and ur stealership can't really be trusted.
Old May 1, 2016 | 06:29 PM
giorgios's Avatar
Thank you Red Barron for your input. I will take it to another mechanic. I usually do all my services at the stealership because I have a tough time trust the shoemakers out there that think they are mechanics. But I will not give them $3000.
Jusseth
Sep 13, 2020 12:25 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
si_driver
Jul 14, 2015 12:29 PM
