Getting my G in spec
Old Jun 17, 2012 | 06:26 PM
aeroheli's Avatar
I lowered my 07 G35X about 3 weeks ago by having an Eibach Pro lowering kit installed.
Now I just took it to a shop for an alignment and was told that the camber could not be brought to spec.
Report:
Front left camber - 1.6
Front right camber -1.2
Front left toe - 0.2
Front right toe - 0.2
Rear left camber -1.9
Rear right camber - 1.9
Rear left toe - 0.5
Rear right toe - 0.5
He mentioned that I'll need a $240 kit to bring it back to spec, however Eibach's website has the 5.72265K for $80. Am I being up-sold, or is he right?
Old Jun 17, 2012 | 07:30 PM
CFitz's Avatar
Actually, the 5.72265K can be found for $55 (on TireRack). While that is much cheaper than $240, the 5.72265k is only for the rear wheels. So you'd need to pick up a set made for the front, which happens to be more pricey... Together I can imagine they could be $240, though he probably isn't gonna use the Eibach kit
Old Jun 17, 2012 | 07:34 PM
Shanes_G's Avatar
your fine. you should have no tire wear at all after the alignment, if thats what your worryed about.all of your wheels are toed in so that compensates for the camber, your cambers not bad at all.
Old Jun 17, 2012 | 07:39 PM
Triton3.5's Avatar
Def. fix the toe,,,front and back,,, camber is more than i'd run around with.....
Old Jun 17, 2012 | 07:42 PM
Shanes_G's Avatar
im running oem camber -2.5 f -3 r all for tires toed in. no tire wear at all. i also paid 300 for my alignment.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
