Mini-review of the Orange TPMS Retrofit Kit
Old Aug 1, 2012 | 07:13 AM
soundmike's Avatar
Originally Posted by kool_yaar
^ thats even better! i just hope that it doesnt leave any sticky residue with so much heat around which is why i was thinking tint, not that it would too hard to remove the residue though
I can assure you no residue is left behind. What irks me though is how the clear plastic covering the gauges (micro)scratches so easily. Even after i've polished it, several weeks later of careful microfiber wiping, the scratches are back.
Old Aug 1, 2012 | 08:29 AM
SCOOBY617's Avatar
this will get rid of the TPMS light on the dash once installed without having to go to the dealership?
Old Aug 1, 2012 | 11:25 AM
vqsmile's Avatar
They're just talking about covering up the light so that you can't see it.
Old Aug 2, 2012 | 12:35 PM
blklegend's Avatar
How did you guys put tape over it? Isn't there a cover? also removing the bulb is gonna be tough, its a solder on LED.
Old Aug 2, 2012 | 04:07 PM
vqsmile's Avatar
You guys are really over-thinking this
They just stick tape on the OUTSIDE of the cover.
Old Aug 3, 2012 | 11:05 AM
blklegend's Avatar
But thats not really a clean look. I think the tape on the cover is going to bother me even more..lol
Old Aug 3, 2012 | 11:40 AM
JOKER's Avatar
CLUB MODERATOR
I don't know how effective this method is and it's only good for those who still have their OEM TPMS sensors.
I heard guys making a pressure chamber out of PVC pipe to keep the OEM TPMS sensors in.
You get a pvc pipe that fits all 4 sensors, cap it from both sides and install air fitting into one of the caps.
Then simply pump it up to 35 psi and throw it in to the trunk. So your system thinks that your tires are within required pressure range.
Once again, this is just something I heard from few guys, I never actually seen one and don't know how effective it's going to be, so don't quote me on this.
Mod is simple and inexpensive enough to try tho.
Old Aug 3, 2012 | 09:16 PM
kool_yaar's Avatar
^ that was tested by someone a while back but apparently it does not work with the newer sensors/tpms system
Old Aug 13, 2012 | 12:46 PM
ALSHUBCAPS's Avatar
just so you know Orange is out of business. they were good but did have a higher then acceptable fail rate. If you have them & they work then you should have no problem, if you do have a warrantee issue then you are SOL.
AL
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
