Clucth pedal problem??
Old Jul 18, 2012 | 09:14 PM
lifted-d's Avatar
my zspeed slave is still going with my jwt clutch, i blew a new oem slave in a few weeks, i would recommend the upgrade to zspeed, as labor is expensive....
Update post, October 3 2012. the Zspeed HD csc is still smooth and excellent, have put almost about 25000 km on it since install. I'm planning to re bleed it soon (per intructions) to flush any moisture out as it is a metal unit not plastic like oem.
Old Jul 18, 2012 | 10:49 PM
Fendi35's Avatar
Originally Posted by vqsmile
Was the slave cylinder replaced when you did the clutch job last year? If so, I would think there should be a warranty on it. If it's the original though, and it's not included in the recall, then unfortunately it's on you.
HMMM . . . Re-reading the previous posts made me want to clarify whether the service rep said that the VIN number wasn't included in the recall, or if it had already been performed on that VIN so it wasn't covered again.
Il have to check on the clucth if it came with it and when I called the dealer and gave my vin he said there is open recalls on my car
Old Jul 19, 2012 | 12:52 AM
Fendi35's Avatar
Going to pull the trigger on oem Orderinfinitiparts.com for 86.58 really want my car ASAP so With over night shipping comes out to 120 or so. Hopefully Rick will get back to me soon serif he will give me a better deal
Thank you all for input
Old Jul 19, 2012 | 12:57 AM
vqsmile's Avatar
Wait . . . If there is an open recall, then it should be covered. Or was that a typo??
Old Jul 19, 2012 | 03:11 AM
kool_yaar's Avatar
^ i think its a typo he did say first that the dealer said there was no recall on his car...
@Fendi35: let us know how it goes and make sure they get all the air out of the system after install and use DOT4(compatible with dot3) which has a bit higher boiling point which can only help
Old Jul 19, 2012 | 12:56 PM
Fendi35's Avatar
just curios how do i flush that fluid...?
Old Jul 19, 2012 | 02:20 PM
kool_yaar's Avatar
Well when they change the slave they will automatically be adding new fluid in their so its not technically a flush but rather a refill in which case any good mechanic would properly bleed the air out using the bleeder valve on the slave after install
Old Jul 22, 2012 | 01:47 AM
maizer89's Avatar
yea there was only one recall for manual i think, but eh didn't change a thing
Old Jul 22, 2012 | 05:01 AM
kool_yaar's Avatar
^ actually it did, it was a revised slave cylinder which does not fail like the old one after continuous city driving
Old Jul 23, 2012 | 03:01 PM
Fendi35's Avatar
Update: Got my car finnaly done omg what a difference. Car is a lot smoother now and the chatter noise from when my car is neutral it's pretty much gone can't hear a thing. even the gears now are a lot more smoother. I have no idea why was it like it was before but not that's all said and done I'm really happy.
Thank you all once again for your input.
Old Jul 23, 2012 | 03:46 PM
kool_yaar's Avatar
^ glad you got it done! if you dont mind how much did you end up spending total on part and labor? tnx
Old Jul 23, 2012 | 04:14 PM
Fendi35's Avatar
87 + 18 for over night shipping = 105
Towing =65
Labor=350
Total = 520
Old Jul 23, 2012 | 05:08 PM
kool_yaar's Avatar
^ Thanks! thats not too bad if you ignore the towing which is REALLY cheap, over here they charge $80 just for hook up!
Old Jul 23, 2012 | 10:15 PM
Fendi35's Avatar
Well the chatter is back lol when in neutral it was short lived but the car still feels better the clucth engagement and the gear shifting
Old Jul 23, 2012 | 11:26 PM
  #30
vqsmile's Avatar
Well the chatter is back lol when in neutral it was short lived but the car still feels better the clutch engagement and the gear shifting
Yeah, I was kinda wondering how the heck a new slave cylinder would have any effect of that.
