Calipers
Old Jul 25, 2012 | 05:41 PM
bwalsh's Avatar
Calipers
So I bought hawk pads and stoptech f/r drilled and slotted rotors. I am trying to by calipers now and for some reason I am being told I can't by anything besides stock calipers! Does this make sense? I just want an upgrade and something that will look and ride right.
Old Jul 25, 2012 | 05:45 PM
AzuMaster's Avatar
If you purchased the stock size pads and rotors then only the stock size calipers will fit. If you have yet to open them, return everything and then buy a set Akebono BBKs from a vendor on this site. Or try to find a used set of Bembros from early model Gs or Zs. Or you can try and get the whole set up off of a G37.
Old Jul 25, 2012 | 06:32 PM
kool_yaar's Avatar
^whs, u would need an entire new BBK kit with larger rotors. If you want to keep the OEM size rotors and pads then you would have to stay with OEM calipers, maybe just paint them if you want them to stand out.
Old Jul 25, 2012 | 06:51 PM
Rollo's Avatar
Also if you get a BBK be sure it will fit under your wheels...
Old Jul 25, 2012 | 07:24 PM
bwalsh's Avatar
K, thanks a lot. Will the calipers off a newer g37 work. Sorry for all of the questions just want to get it right the first time around. U guys rock thanks
Old Jul 25, 2012 | 10:04 PM
kool_yaar's Avatar
^ if youre talking about the G37 Sports OEM Akebono BBK that come stock from the factory then yes they will fit perfect as long as you get the entire kit(rotors, pads, calipers, other small brake hardware).
FYI if you plan to go with Z1 SS lines then you need another part that u have to buy separate, theres a recent thread on that here.
seagrasser
May 3, 2022 09:43 AM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
Visionnn
Oct 3, 2015 05:16 AM
dcsbh1
Oct 1, 2015 03:15 PM
NJ6MT
Sep 10, 2015 08:40 AM
