noise after turning off a/c
Old Aug 6, 2012 | 02:59 PM
ds14x's Avatar
Wondering if anyone has a noise that only happens once u turn off the a/c. Hard to explain what it sounds like just the belts but higher pitched. But it only happens after u turn the ac off and not when its running. Thx for any opinions!
Old Aug 6, 2012 | 03:44 PM
muyrec's Avatar
Just did this thread. Does it sound like this? https://g35driver.com/forums/g35-sed...ise-video.html
Old Aug 6, 2012 | 04:10 PM
vqsmile's Avatar
Just for clarification, are you saying the noise only happens for a moment or so after you have been running the AC and then turn it off? . . . OR, are you saying it makes the noise the entire time the engine is running and you have the AC switched off?
My guess is that it's the clutch on the compressor acting up. If the noise is just brief, it's probably not a big deal, but if it's constant when the AC is off, then it could be serious.
Old Aug 6, 2012 | 04:14 PM
vqsmile's Avatar
Good thread there muyrec. Thanks for making that!
Old Aug 7, 2012 | 12:04 AM
ds14x's Avatar
actually the above video is the explanation of another noise I have lol. But the problem I am referring to actually does go away after a few minutes of running the engine with the a/c off, well just gets quieter. but it is pretty loud right after you turn off the a/c
Old Aug 7, 2012 | 06:56 AM
LeFrenchy's Avatar
Are you talking about a wheel of fortune type clicking noise after you turn it off?
Old Aug 7, 2012 | 10:01 AM
ds14x's Avatar
Yes! That exactly describes it
Old Aug 7, 2012 | 03:21 PM
LeFrenchy's Avatar
There's a TSB regarding this. Some silicone gets stuck in the heater core and does this.
I'll find the tsb link for ya when I'm on a pc.
Old Aug 7, 2012 | 08:43 PM
ds14x's Avatar
awesome, thanks a lot!
Old Aug 8, 2012 | 02:03 AM
kool_yaar's Avatar
I think LeFrenchy was referring to THIS
Old Aug 8, 2012 | 04:50 PM
RedBaronK's Avatar
I had this exact issue, along with the loud compressor issue that muyrec and I have been discussing. The noise after AC was shut down was from a bad pulley. The belt was like new, but the pulley was bad. If it gets worse, u will also start to hear ticking sounds while its running. Replace the pulley and its solved... tell the dealer its intermittent and if they r nice, they will take ur word for it and replace the pulley and belt if ur under warranty
Old Aug 9, 2012 | 12:12 PM
ds14x's Avatar
Ah ok. Not under warranty anymore so ill just take it in if it gets worse. Thanks for the info!
Old Aug 10, 2012 | 09:33 PM
Gunnnnzzz's Avatar
my ac makes noise also
Old Aug 11, 2012 | 06:15 PM
RedBaronK's Avatar
Welcome to the club... if u do a search u will be amazed how many people have loud compressors... I am on my 3rd
G35Rican
Jul 31, 2024 01:37 AM
magnetism80
Feb 1, 2019 10:00 AM
JLee301
Sep 25, 2015 08:46 PM
mattdg35
Sep 14, 2015 11:28 AM
NJ6MT
Sep 10, 2015 08:40 AM
