Fuel Reserve
Old Aug 10, 2012 | 08:54 AM
Ingeo's Avatar
Fuel Reserve
I've searched through the manual and poked around a little online but cannot find anything definitive about whether an 08 G35x Sedan has a fuel reserve or not. Either it does or the gas bar I filled up at over the weekend calibrated the pumps to rip people off because I put 64.5 litres (17.03 gal) into a 60 litre (15.85 gal) tank 0.o
Old Aug 10, 2012 | 08:59 AM
rpm&my_G35's Avatar
The fuel tank is 76litres (20 US gal).
Owners Manual, Section 9 - Capacities...
Old Aug 10, 2012 | 09:04 AM
jninja26's Avatar
Ummm...what makes you think a 2008 g35x has a 15 gallon tank? Its not. Its 20 gallons.
Old Aug 10, 2012 | 09:07 AM
Ingeo's Avatar
I've filled up from just about bone dry 6 times, there is no way this car has even a 70 litre tank let alone a 75 litre tank. Just because the stock is 20 gallons doesn't me it wasn't changed!
Old Aug 10, 2012 | 09:23 AM
jninja26's Avatar
Ughhmmm...okay. I guess.
Old Aug 10, 2012 | 09:28 AM
jninja26's Avatar
I would ask why you have a 15.5 gallon tank from a different vehicle, on a 4 y/o G...but...I just don't care
Old Aug 10, 2012 | 09:43 AM
rpm&my_G35's Avatar
If you believe this to be a possibility then your first post is moot and no one here could help answer your question based on a non-stock fuel tank.
As we said, a stock 2007+ G35/G37 sedan fuel tank is 76L or 20 US gal.
Old Aug 10, 2012 | 09:45 AM
Ingeo's Avatar
I had no reason to think the tank was not stock as the only other owner was a lease. I'll get under the car and measure the tank after work because it does not hold anywhere near 76 litres.
Old Aug 10, 2012 | 09:49 AM
rpm&my_G35's Avatar
I've had a 2007 G35 X (4years) and now a 2011G37S. I have never been able to get more than about 65/66L in the tanks after the gas light comes on. Same goes for most guys here.
There is a reserve of a couple gallons.
I'm going to say that you put 64.5 litres (17.03 gal) into a 76 litre (20 US gal) tank and that it's completely normal.
Old Aug 10, 2012 | 09:54 AM
Ingeo's Avatar
Thanks
Old Aug 10, 2012 | 01:11 PM
maizer89's Avatar
if your only able to fill 15 gallons when you get the fuel warning light, I would maybe check with the dealer I remembered there was a tsb for it, I believe that the infiniti should have a capacity of 20 gallons just like every says but its not all in one tank there is actually a small seperate tank and there is a pump that pushes gas between the two and sometimes that pump doesn't work.
Old Aug 10, 2012 | 01:16 PM
rpm&my_G35's Avatar
He said he put in a little over 17 US gal. It's normal. Everything is alright.
Old Aug 10, 2012 | 01:39 PM
jninja26's Avatar
Old Aug 10, 2012 | 01:45 PM
jninja26's Avatar
Yeah! Show that gas station what's up! But make sure you get under the car while its moving, so you can get an accurate measurement
Old Aug 10, 2012 | 02:01 PM
vqsmile's Avatar
I don't understand why people seem to have such a hard time reconciling how the tank capacity is not the same as the calibration of the fuel gauge, and hence the whole concept of a RESERVE.
