reverse and daytime lights
Old Aug 10, 2012 | 10:37 AM
SofaKingAzn's Avatar
for 2007 G35x what type of led replacement reverse lights can be installed? and also for the headlights is there a way to replace the stock yellow daytime running bulb beside the xenons? thanks!
Old Aug 10, 2012 | 01:17 PM
maizer89's Avatar
check out this thread (http://www.myg37.com/forums/d-i-y-in...ion-guide.html)
i'm not sure if it deals with the day time bulbs but it answers your reverse lights. About the daytime I think it is easily replaceable just search sylavania bulb guide, but you may have to take out your bumper to take your headlights out to access the bulbs.
Old Aug 12, 2012 | 02:22 PM
alright thanks!
Old Aug 13, 2012 | 06:15 AM
parthur's Avatar
Hello there, just to clarify... no you do not need to remove the bumper to replace the day running lights (fog lights), Its a little thigh but you can do it from inside the bay. ( I did it not long ago on my 2008 G35X) so should not be a problem.....
Old Aug 18, 2012 | 01:49 PM
rollaspeed1's Avatar
i replaced my day time running lights to white/light bluish. Pretty easy to do without removing the bumper. I also replaced the 4300K stock HIDs with x000Ks while I was at it! And I dont remember the code but google it and it'll pop right up
Old Aug 20, 2012 | 11:03 AM
Canadian35x's Avatar
I used these for my reverse lights and they are like having a set of headlights in the rear (especially if you have the reverse camera!!)
http://www.ebay.ca/itm/2x-T10-15-Cre...item336a6ffd03
I wanted something that was really bright and functional and not just for the look. So with these I got both! I'll try and get a pic of them tonight.......
Old Sep 6, 2012 | 11:50 AM
SteveScenna's Avatar
Where did you get the daytime running lights from?
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
youngdip631
Lighting
Aug 31, 2015 09:13 PM
ghost_g35
Aug 7, 2015 10:31 AM
