Rear Differential
Old Aug 11, 2012 | 08:15 PM
Stevins's Avatar
Rear Differential
So I finally changed out the oil in my rear diff today and while I was doing it I noticed that I have a small oil leak. It seems to be coming from where the drive shaft meets the rear diff. Does anyone know what this is? Thanks in advance.
Old Aug 11, 2012 | 08:30 PM
Triton3.5's Avatar
pinion seal/bearing prolly,,, some never leak, some leak a little, how many miles on car? don't think i'd worry about it if its only a drop now and then.....
Old Aug 11, 2012 | 08:37 PM
Stevins's Avatar
It looks like just a minor leak. I assume the oil I see is from the rear diff? How much is this to fix?
Old Aug 12, 2012 | 09:55 AM
Triton3.5's Avatar
yes, it is diff. oil,,, this is a little techical to fix,,, thats why i was wondering how many miles,, if your still in warranty,, i am not sure if the pinion would have to come out or not,,, if not, then just a new seal. but you'd still have to take drive shaft off, and undo large nut to get at part...however i have never attempted to do this on any vehicle...
Old Aug 12, 2012 | 09:57 AM
Stevins's Avatar
Ive got about 56k on my 08x. I assume this will get worse over time....
Old Aug 12, 2012 | 12:07 PM
vqsmile's Avatar
Since you're under 70K, then you should still be covered under the drive train warranty. Take it to the dealer.
Old Aug 12, 2012 | 01:20 PM
Stevins's Avatar
Thanks guys
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
