Mind of its own - Random window/light operation
Old Sep 15, 2012 | 12:18 PM
ThatsMyG's Avatar
My daughter just came home and asked 'whats going on with your car?"
It was parked in the driveway for an hour, so I said - "nothing - why".
She said she jsut pulled up and notices the drivers windows was going up and down, passenger window and rear wind also doing the same, inside lights flashing, etc. They it stopped.
Indeed when I went outsidee the drivers windows was half way down,
I give up - what is the car trying to tell me ( other than it being possessed).???????
Had this happened during the week, I'd likely end up with a dead battery - so this is pretty serious.
Any hints?
Old Sep 15, 2012 | 12:38 PM
vqsmile's Avatar
Make sure you're not accidentally pressing the key fob buttons n your pocket; depending on your proximity to the car, it can pick up from quite a distance. It is also possible that the key fob unit is malfunctioning itself too.
Old Sep 15, 2012 | 12:57 PM
ThatsMyG's Avatar
Originally Posted by vqsmile
Make sure you're not accidentally pressing the key fob buttons n your pocket; depending on your proximity to the car, it can pick up from quite a distance......
But can I open windows with the fob ?? How?
Old Sep 15, 2012 | 01:03 PM
vqsmile's Avatar
Yes, it can; it's all in the normal operational capabilities of the fob. All the details are covered in the Owner's Manual.
Old Sep 15, 2012 | 01:08 PM
kristof's Avatar
The fob is not going to make the windows go back up.
OP - go outside and hold your unlock button to see what happens.
Old Sep 15, 2012 | 02:19 PM
vqsmile's Avatar
^^ Yep, yep, you are right kristof. It's only with the metal key in the door lock that you can roll them up. Good catch.
Old Sep 15, 2012 | 05:32 PM
ThatsMyG's Avatar
Originally Posted by kristof
....OP - go outside and hold your unlock button to see what happens.
Well, it does what it always does, headlights flash, and the door unlocks
HOLDING the unlock does not to anything special for me. Are you saying holding the unlock key is supposed to open the windows????
Old Sep 15, 2012 | 06:34 PM
vqsmile's Avatar
Yes, holding the button down for another 5 seconds or so will start the windows rolling down. If it doesn't, you either have a bad battery in the fob (can't hold signal for long enough to activate down function) or else the intelligent key system and/or lock system is malfunctioning. A quick test to see if your windows will work when activated with the lock system is to pull the metal key out of the fob and use it in the driver's door lock.Turning left or right unlocks or locks the door, and as with the remote, if held for another 5 seconds or so in either position it will activate the windows up or down accordingly.
Again, as I mentioned before, this is all detailed in the manual. If you don't have one, you can download it for free from Infinitihelp.com.
Old Sep 16, 2012 | 12:12 AM
Mike45's Avatar
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
KallDay86
Jan 8, 2016 12:42 AM
BradMD_96
Oct 6, 2015 09:31 AM
