Car is not starting
Old Oct 8, 2012 | 02:49 PM
mrley67's Avatar
Car is not starting
Hello, Guys. I am having problems starting my car. I checked the battery using a battery charge test and it came out fine. Anybody else had this problem before?
Thanks.
Best,
Michael
addition Info, I used the car this morning and it was fine but when i got home, It wouldnt start.
2007 G35S
90,xxx miles
http://youtu.be/CkKuDPjAjdA
<iframe width="560" height="315" src="http://www.youtube.com/embed/CkKuDPjAjdA" frameborder="0" allowfullscreen></iframe>
Old Oct 8, 2012 | 04:22 PM
Triton3.5's Avatar
could have used alittle more, additional info.... If your still on the original battery, thats prolly it, your is just taking its time going out, otherwise, if it turns over and does NOT start, then you have bigger problems, or if it doesn't turn over, it could be lots of things,, key fob not commicating properly, dead key fob bat. or you have open circut somewhere thats draining Battery... I know i'm still on original battery, and i'm gonna replace it before winter,,, ie real quick!!
Old Oct 9, 2012 | 12:06 AM
Shurik355's Avatar
hmmm sure sounds like a battery! in the video all you tried is starting the car right away. But what about just pressing the start button without depressing the pedal to start it. Do the lights stay on or what?
Old Oct 9, 2012 | 02:44 AM
vqsmile's Avatar
Originally Posted by Shurik355
hmmm sure sounds like a battery! ...
^^ Ditto.
What exactly was this "battery charge test" that was done? Have you measured the voltage at the terminals? Is it right around 12.6V ? Turn the headlights on and then remeasure it; is it still 12.6V ? Have you tried to jump start from another car with some jumper cables?
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
realtalk21
Jul 20, 2015 09:07 AM
