What tire pressure you are running on 18" Sports rim on street?
Old Oct 10, 2012 | 06:09 PM
stockae92's Avatar
I think factory recomended is 33 psi all around. I am running 34 psi. I don't know if I should run higher for better mpg?
Old Oct 10, 2012 | 06:40 PM
hcag2's Avatar
35-38 psi is good enough for me.
Old Oct 10, 2012 | 07:03 PM
cvipgo's Avatar
I put 35 psi on my 03 g35c
Old Oct 10, 2012 | 11:59 PM
jkat13's Avatar
34-35 psi. Slightly above recommended so TMPS does not cause problems when it cold out. Anything higher and ride feels bouncy to me.
Old Oct 11, 2012 | 04:44 AM
TORETTO's Avatar
you have no idea what bouncy is
Old Oct 11, 2012 | 03:18 PM
VMRWheels's Avatar
34-35 should be fine.
Old Oct 11, 2012 | 08:31 PM
stockae92's Avatar
hummm ... i might try 35 psi and see how it goes
Old Oct 11, 2012 | 08:33 PM
VMRWheels's Avatar
Honestly going between 34psi and 35psi won't make too much of a difference. If you want to see the adverse affects of tire pressure though, Mythbusters did a special on over, under, and correctly inflated tires haha.
Old Oct 12, 2012 | 09:23 AM
soundmike's Avatar
What's the tire rating? That'll determine minimum pressure you should run. Anything above it is just tweaking.
Also, note that temperature will affect the running pressure. On a nice summer day, driving down the highway, my 32 ends up peaking at 36 or so. So, your 36 could theoretically push it in the 40s.
During the last cold front, it never made it above 33.
Old Oct 15, 2012 | 04:09 AM
maizer89's Avatar
yea i usually go 33 gives good wiggle room and esp with bump roads a more mellow psi is always welcomed
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
multimut
Canada
Jul 26, 2015 08:43 PM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
