Coolant system capacity?
Old Oct 16, 2012 | 04:51 PM
Triton3.5's Avatar
So guys, today i drained and refilled car, sort of flushed system, with garden hose, and had the heater turned up all the way to 90* with fan on about 4 bars, with engine running, then shut off, then start again, finally had mostly clear water running out both the drain valve, ( on pass. side) and also pulled lower radiator hose to get more out,, I swear though that i got more out than i put back in!! Opinions please!!! only got 6 qts. back in,, it sure seems like 3 gallons came out,, actually had quite a mess took undertray off to make it easier to get at stuff. I drove car 6 or 7 miles, with heater on, then off, then airconditioning on, then off, temp gauge stayed where it always does! So do you all thing i'm good to go?? also flushout overflow tank. car is almost 6 years old now so it was dew... actually the old stuff looked pretty good yet, allthough i did NOT test it for freezing strength.....
Old Oct 16, 2012 | 05:06 PM
vqsmile's Avatar
Factory Service Manual says 9-1/2 quarts including the reservoir to the MAX level. It also says that you should ONLY use distilled or de-mineralized water to mix with the antifreeze.
Old Oct 16, 2012 | 05:14 PM
Triton3.5's Avatar
thankx VQ! was hoping you or Kool would give your opinions....10/4 on that capacity.. still can't fiqure out why i could NOT get more in,,, you'd think with BOTH the drain petcock open AND the lower radiator hose off i got ALL the old stuff out right?? don't get why i'm about a Gallon short!! side note, put back in zerez asian formula 50/50. only other reason could be...... maybe i DIDN"T get all the old out?? but i'll tell ya, i got a 5 gallon pail thats almost half full,, plus i made quite a mess on the ground...... i guess i'll be watching it....
Old Oct 16, 2012 | 05:27 PM
joedaddy1's Avatar
how did you refill.. did you take off the relief valve in the back?
Old Oct 16, 2012 | 05:30 PM
Triton3.5's Avatar
had it loosend, and out, tried burbing the system, by squeezing hoses,, new coolant went in fairly slowly also......
Old Oct 16, 2012 | 07:00 PM
vqsmile's Avatar
If you want to do a complete draining, there a two coolant drain plugs in the engine block that need to come out, since the block does hold a bit. Short of that, you can do repeated flushes with distilled water to dilute the residual coolant left in the block to nil.
Old Oct 16, 2012 | 07:16 PM
Triton3.5's Avatar
yes i thought about that, the price for having a lowered car, is its very difficult to get under just the front, let alone under the motor,, i didn't know where to look for those( block drains) and gave up looking for em. i do not have a lift. had to stack 12 2x6's and sort of drive up on them so i had a little room to work. ah well,, i will certainly watch it, the next few drives.... thankx for the input gentlemen!!!!
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
