Is the G35x front wheel based or rear?
Old Oct 25, 2012 | 08:24 PM
SofaKingAzn's Avatar
So recently I was at a nissan dealer to buy a sentra and they said my 07 G35x is rear wheel based, so in dry conditions pretty much 100% of the power goes to the rear. But from my observation the G is front wheel based because I noticed more wear on the front tires, idk if its cause of tire rotation or not because I bought this car second hand. I know snow mode is 50/50 split, but what about just normal? can someone clarify? thanks
Old Oct 25, 2012 | 09:41 PM
RedBaronK's Avatar
Rear man.... its not a ford escort.
Old Oct 26, 2012 | 12:04 AM
Oh ok that's good to hear I thought I was just a honda in disguise haha. so the previous owner must have done a tire rotation I guess, cause my front tires have noticeably more wear than my rears
Old Oct 26, 2012 | 12:19 AM
RedBaronK's Avatar
The previous owner either didn't rotate enough if theres a huge wear discrepancy between front and back.... Or depending on wear patterns u may need an alignment.
Old Oct 26, 2012 | 09:54 AM
ummm from what I can tell the tread difference is around 1mm but its definitely noticeable when you look at the very outside part of the tire. what kind of wear pattern would mean a alignment is needed? thanks
Old Oct 26, 2012 | 01:30 PM
jkat13's Avatar
Rear tires go way faster on my X than the fronts. Especially the right rear. In general, if you don't see even wear across the tire you may have an alignment issue. On the rears you may see the center third of the tread wearing faster than the outsides, that is normal.
Old Oct 26, 2012 | 05:19 PM
RedBaronK's Avatar
https://g35driver.com/forums/showthr...76#post6610076
This thread has pics of tire wear.
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
rping
Jul 26, 2015 09:53 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
