Road vibration/judder gone!
Old Oct 25, 2012 | 10:07 PM
krazyket's Avatar
I was due for a tire rotation and took my car to a local town fair tire. When my friend drove my car last night, he told me to get an alignment done too since the car was vibrating at high speeds.
It seems that after tire rotation, wheel balancing and wheel alignment. Car feels a lot different, it runs more smoothly and it's more agile in corners.
Here is the print out from the before and after:
Road vibration/judder gone!-mssecl.jpg
Old Oct 26, 2012 | 01:44 AM
RedBaronK's Avatar
I got humming sounds at 58-62 only... no vibrations though. Usually I was told a bad alignment is responsible for car drifting to left or right while driving on flat land... not humming or vibrations. So, my guess is ur balancing took the vibrations away.
Can someone verify that alignments don't usually cause vibrations?
I did get an alignment, but the dealer didn't give me any fancy print out like yours, so there's no way for me to know if they actually did anything...
Replaced both front wheel bearings, still no use. Next step is to have the dealer raise car on a lift, bring the speed to 62, and look under the car for the source of the humming..... and I guess ill have them check alignment too
Old Oct 26, 2012 | 03:09 AM
dukehotty's Avatar
If your tires get louder when you are coming to a stop, then it's your tires "feathering"
Old Oct 26, 2012 | 09:55 AM
krazyket's Avatar
Yea, I was told that when they balance the wheel they can see if your rim is bent or your tires need to be rotated. To balance the car, they usually put bad tires in the rear. I also noticed they installed new stick on wheel weights for balancing. So far, I am happy with the overall results of the car and def worth the cost of enjoying the smoother ride.
Old Oct 26, 2012 | 10:00 AM
krazyket's Avatar
Old Oct 26, 2012 | 01:56 PM
VMRWheels's Avatar
My guess is that it's your tires. Not all tires are quiet, especially after they've gotten some wear on them.
Old Oct 26, 2012 | 05:16 PM
samuel1021's Avatar
I'm currently dealing with something similar to this, only I don't know how to diagnose it. I'm thinking I could have a bent rim, or maybe my tire(s) need to be balanced/rotated. When accelerating/decelerating, I hear a loud flapping noise. I definitely know it has something to do with the wheels. I've checked under the car to make sure none of the linings are hanging or anything of that nature.
Anyone dealt with this before?
RedBaronK's Avatar
Its not... I replaced it with brand new ones from different manufacturer ... so far I ruled out tires, front bearings... such a nagging issue .. driving me nuts.
Old Oct 26, 2012 | 07:00 PM
VMRWheels's Avatar
What tires were you using before and what tires did you replace them with?
Old Oct 26, 2012 | 08:23 PM
Anton_Chigurh's Avatar
I wish this would cure my vibration...i had 3 alignments in 1 year last year along with the 4 different tires...no chance at all....I just gave up looking for it..something hopefully will fall off soon and then i will know what the issue is..
Old Oct 26, 2012 | 08:44 PM
VMRWheels's Avatar
Bad bushings?
Old Oct 26, 2012 | 08:52 PM
RedBaronK's Avatar
Originally Posted by VMRWheels
Bad bushings?
Trust me.. Anton went through every option... when I was searching for my cure, all I saw were his posts going back 3+ years.... right upto when his engine blew up and dealer had it for 2 months...
Old Oct 26, 2012 | 08:53 PM
RedBaronK's Avatar
Cheap *** OEM hankook ventus v4ES to michellin mxv4... same issue. Either two places I had my wheel rotation and balance done sucked *** or its another part of the car.. maybe drive shaft or rear wheel bearings. The quest continues...
Old Oct 26, 2012 | 10:16 PM
yup...i have a lemon baby..still like it..besides that god dam vib..if i stay below 71 mph i can tolerate it...75 and up...F that can't do it anymore
Old Oct 29, 2012 | 12:35 AM
Chumacher's Avatar
My car has the same problem. If it becomes more common Infiniti will have to do a recall. I hear excessive road noise from the front left tire when driving over 50km/h. We should start a poll including all G owners to find out who else has this problem.
