Power Steering Flush or DIY reservoir pump?
Old Nov 19, 2012 | 07:29 AM
stevesg35's Avatar
My G is coming up on 5-years old and I've changed all fluids - even front and rear diffs and transfer case - but not the power steering fluid. What do you guys recommend?
1. Do nothing - it's fine to not change
2. Use a hand pump - in my Lexus I was able to pump out 1/2 quart from the reservoir, add ATF, drive a week, and repeat
3. Get a power steering flush
Thanks.
Old Nov 19, 2012 | 09:41 AM
rpm&my_G35's Avatar
1. Did you inspect the PS fluid? If it's redish/transparent then leave it, it's fine. If it's become black and impossible to see through then change it.
2. If you are going to change it then this is the easiest DIY method for the average person.
https://g35driver.com/forums/g35-sed...ing-fluid.html
http://infinitihelp.com/diy/gsedan/p...stallation.php
Old Nov 19, 2012 | 12:14 PM
vqsmile's Avatar
It's simple enough to change it out. Either a turkey baster or hand pump will work just fine. Here's a 'local' (ie. V36) DIY for you:
https://g35driver.com/forums/v36-diy...id-change.html
Old Nov 19, 2012 | 04:58 PM
RedBaronK's Avatar
Soundmike's DIY saved me a ton of money and o spent 12 bucks doing something stealershit would have charged me 80+ for. Its easy as hell... go buy a 3 dollar siphon pump or a Turkey baster like VQ said.
Old Nov 19, 2012 | 08:46 PM
stevesg35's Avatar
Thanks for the replies. I will check it and anything but a nice cherry red I will follow the linked DIY's. Thanks again.
Old Nov 20, 2012 | 11:49 AM
Austin713's Avatar
i did the linked DIY. i probably drained and filled 3 times, each time turning my wheel completely to the left and right to circulate the fluid.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Blakearold
Aug 27, 2015 12:37 PM
Phenomenon9
Aug 9, 2015 01:34 AM
RedBaronK
Jul 27, 2015 06:25 PM
