Hey guys, i got my new wheels mounted today and everything went smoothly. Except for one thing, the rear center caps can't be put on because a nut under the center cap sticks out too far. Anyone else run into this problem with aftermarket wheels? Any ideas on how to combat this?
Thanks!
Thanks!
Quote:
That's what I was thinking but I don't want my wheels pushed out any fartherOriginally Posted by muyrec
Spacers would be my best guess.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Quote:
True....^....or quite possibly you bought the wrong wheels that weren't designed to fit your G! Originally Posted by vendwarfare
High type center caps might help you out
Gary
Different caps or a small spacer. How much clearance do you think you need? If it's only a couple millimeters maybe try a 3mm slip on.
Others have sanded down the inside of the center cap. Not sure how much material you have.
http://www.myg37.com/forums/3366836-post48.html
Here is the center cap for those of you wondering what it looks like
I think I'm just going to go with a small spacer. I think a 10 mm spacer will do the trick.
I also attached a picture of the front center cap that fits correctly.
herrschaft
close
- Join DateJul 2009
- LocationCoast
iTrader Feedback Score(18)
Liked:771 Times in 605 Posts
No you didn'tOriginally Posted by Globo Gym
Quote:
My computer and phone are freaking out so they'll be up as soon as possibleOriginally Posted by herrschaft
No you didn't
10mm spacers will definitely add quite a bit of extra clearance, and I think that will also work.Originally Posted by Globo Gym
Here is the center cap for those of you wondering what it looks like I think I'm just going to go with a small spacer. I think a 10 mm spacer will do the trick.
Quote:
Images didn't work...Originally Posted by avangeline
Quote:
Thanks for the input. Havent had time to get those pictures on but will probably be able to tomorrow. Stay tuned!Originally Posted by VMRWheels
