Intelligent Cruise Control Limitation?
Old Mar 2, 2013 | 08:14 PM
MikeJones916's Avatar
Hey All.
So I know when you drive into direct sunlight the ICC will shut off.
I'm ok with that.
What I am wondering is, is there a way to just use normal cruise control?
For example, can I go "old school" and just select and set the speed I want?
It seems like its ICC or bust, and because my evening commute is in the sun ICC shuts off, which is annoying.
Infiniti limitation or is there a workaround?
Let me know!
_Michael
Old Mar 2, 2013 | 09:25 PM
soundmike's Avatar
There are more limitations to it, it's in the manual. Section 5-21 onwards.
Section 5-38, to use conventional cruise:
Operating conventional (fixed speed) cruise control mode
To turn on the conventional (fixed speed) cruise control mode, push and hold the MAIN switch qA for longer than about 1.5 seconds.
When pushing the MAIN switch on, the Intelligent Cruise Control system display and the CRUISE indicator are displayed on the dot matrix crystal display. After you hold the MAIN switch on for longer than about 1.5 seconds, the Intelligent Cruise Control system display goes out. The CRUISE indicator stays lit. You can now set your desired cruising speed. Pushing the MAIN switch again will turn the system completely off.
When the ignition switch is pushed to the OFF position, the system is also automatically turned off. To use the Intelligent Cruise Control again, quickly push and release the MAIN switch (vehicle-to-vehicle distance control mode) or push and hold it (conventional cruise control mode) again to turn it on.
Old Mar 2, 2013 | 11:35 PM
Soundmike you seem to have all of the answers.
Thanks again I will give this a shot tomorrow!
_Michael
Old Mar 3, 2013 | 12:20 AM
kool_yaar's Avatar
Yea mike has always been a show off!! oh i meant helpful, dang this weird auto correct!
Old Mar 3, 2013 | 12:28 PM
vqsmile's Avatar
bahaha . . . yep, damn overachiever!
Old Mar 3, 2013 | 02:09 PM
soundmike's Avatar
_Michael
Welcome.
Love you guys.
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
Terry_G35
Sep 10, 2015 08:17 PM
pasjr1972
Sep 1, 2015 10:17 PM
