Staggered tire on g35x/07
Old Apr 11, 2013 | 10:35 PM
Beto88's Avatar
Can i use 245/18 front 275/18 rear on my g35x/ 07? Or its gonna damage thé car?
Old Apr 12, 2013 | 12:20 AM
vqsmile's Avatar
245/??-18 and 275/??-18
...and with what rims??
Old Apr 12, 2013 | 12:41 AM
Dwowie35's Avatar
245 all around and you won't any problems
Old Apr 12, 2013 | 10:46 AM
Beto88's Avatar
With enkei rims 18 inch and low profile tire 245/40/18 275/35/18
Old Apr 12, 2013 | 12:26 PM
vqsmile's Avatar
If you want a legitimate answer, you need to provide the full specs of what you're proposing. What are the widths and the offsets on those wheels. As far as the tires go, they are fairly similar in diameter to each other, but could be better still, and they are well over an inch smaller in overall diameter than stock, so you're going to have some error factor in your speedo, ABS, VDC, airbag thresholds, etc. Generally, unless you have a specific reason to change overall diameter, it is best to just stick with a combo that is closer to the stock diameters. For instance, if you went with a 245/45 and a 275/40, you'd not only be virtually identical in overall diameter between front and rear, you'd be right at the stock diameter as well, so no issues there.
Old Apr 12, 2013 | 02:06 PM
Beto88's Avatar
I has them installed for 2 week now and no-error appeared. My friend had those rims and give it to me for very cheap for nice rims. I have 1 inch difference in total diameter with the original rims equipped with winter tire. Should be better to roll with vdc off for the computer, to not detect that the rear tire have more traction lol? And I know that the g35x it not fully 4x4 and became rear wheel drive when u go at certain speed
Old Apr 12, 2013 | 07:36 PM
vqsmile's Avatar
Well ok, sounds like you're already using them then. FWIW, to accomodate those tire widths, the rims should be at around 8" in the front and 9.5" in the rear.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
