Transmission Fluid Flush & Cooolant Change Intervals
Old May 5, 2013 | 11:25 AM
g35at's Avatar
In a 2008 G35x, what is the recommended change interval for transmission fluid flush and coolant change? Are 60k mile intervals ok?
Old May 5, 2013 | 01:05 PM
vqsmile's Avatar
This is all covered in the Owner Manual found here for free: http://x.infinitihelp.com/forum/local_links.php?catid=2
Old May 5, 2013 | 01:36 PM
gary c's Avatar
Search is your friend, use it!
The only thing that needs flushing is a toilet! Only time a trans needs flushing is around 100K miles and even Nissan can't make up their mind about that. Drain and fill is what needs to be completed every 30K miles on all fluids, according to Nissan. If you live in a hot climate like SoCal it wouldn't hurt to do the trans drain and fill more often....Gary
Old May 9, 2013 | 02:34 PM
Austin713's Avatar
i do a drain and fill. flush has the chance of forcing contaminants up into the transmission and causing damage.
chinee
Jun 10, 2024 07:48 PM
derres
Aug 28, 2015 03:27 PM
EricF
Aug 28, 2015 08:27 AM
saskicker32
Aug 11, 2015 02:12 PM
underworld
Aug 6, 2015 01:36 PM
