can i remove the exhaust heat shield?
Old May 5, 2013 | 08:54 PM
suby01's Avatar
my heat shields under the floor, that go above the exhaust and in between the drive shaft are rattling. can i just take those off?
will it mess anything up besides the obvious heat travel.
i already too off the one above the X pipe that was a small one but there is a bigger on towards the rear, and it has the brake lines what it seems to me connected to them. can i just unhook the brake lines and remove that shield too?
Old May 5, 2013 | 09:04 PM
dukehotty's Avatar
Why do you want to remove them? Are you going to put them back or are you removing them permanently?
Old May 5, 2013 | 09:09 PM
suby01's Avatar
im thinking of removing them permanently. they rattle a lot under redline.
the end piece is what im talking about shown on the bottom here
Old May 5, 2013 | 09:10 PM
dukehotty's Avatar
In the long run, I think it's best to keep them on and figure out a way to attach them more securely so they don't rattle.
Old May 5, 2013 | 09:33 PM
muyrec's Avatar
haha i have the same problem too. I even bent it a little bit to remove the rattle a few months ago. It's acting up again. Removing mines tomorrow.
Old May 6, 2013 | 12:20 AM
Triton3.5's Avatar
i would just rerivit them, slightly bigger rivet, maybe a washer on one side,, should be gtg,, btw,, very clean under your car,,, particularly the exhaust!!
Old May 6, 2013 | 09:11 PM
suby01's Avatar
^ thanks yeah i just want to remove them. thats not my car its just a pic from google.
Old May 6, 2013 | 09:12 PM
suby01's Avatar
any luck?
i tried to remove it today but it seems like there is the spring that hold the ebrake cable on.
anyone have any idea if that is necessary. or what it does?
Old May 6, 2013 | 10:28 PM
muyrec's Avatar
Nah didn't do it today due to laziness. It's only 4 screws that hold it in place. Don't have to touch ebrake. we're talking about the one with the metal brace going across right?
Old May 7, 2013 | 09:13 AM
soundmike's Avatar
If pushing it back doesn't work, and you're having trouble removing it, just take some tin snips to it. Not pretty, but it'll do the job.
skippyG
Jan 25, 2016 01:18 PM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
linedr89
Aug 17, 2015 05:11 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
