fair price to replace thermostat, flush coolant, new radiator cap?
Old May 9, 2013 | 02:53 PM
ncitrdude's Avatar
Hi folks, tried searching but couldn't find an answer...
I have an '07 G35 Sport Sedan manual with 48K miles. The last few days i've noticed high coolant temperatures (i drive very short distances, so it never got to the point where it overheated/boiled over) that went to the top of the Cold/Hot range on the dash gauge. I could get the temperature back to the normal range by turning the heater on full blast, but that's obviously just a temporary solution. The radiator fans appear to be functioning normally.
In any case, i took it to my local dealer, and they said it is a sticking thermostat. They recommend replacing the thermostat, flushing the coolant, and replacing the radiator cap. The total cost is roughly $420 ($80 in parts, $340ish in labor). They said it was a roughly 2.5 hour job.
Does this seem like a reasonable cost for the procedure? Seems high to me, especially on the labor side/estimated time, but i'm pretty mechanically clueless so i would appreciate outside feedback. Thanks in advance.
Old May 9, 2013 | 03:40 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Well,
FULL retail,
Thermostat w/ Housing - $45.27
Thermostat Housing Gasket - $6.50
Radiator Cap - $35.94
so at full retail here, $87.71 in parts so they are about $7.00 lower than full retail that's probably about the norm when taking your car through service...
as far as the labor for the flushing and replacing all those components, I couldn't answer
someone on here probably can give a better idea on the price of labor, or how much labor it might take....
~Phil~
Old May 9, 2013 | 05:12 PM
GR6RR's Avatar
do it yourself. its not that bad. about 120 in parts and fluids.
Old May 9, 2013 | 11:58 PM
vqsmile's Avatar
It's all pretty easy to DIY, and if you go with quality aftermarket parts, you can cut the parts cost down to a fraction of those prices.
Old May 10, 2013 | 01:11 AM
Jaygotboost's Avatar
If you are in SoCal, I'll do the job for you, for hell of a lot cheaper =)
Old Jun 11, 2013 | 08:30 PM
garreTT008's Avatar
Any follow up to this? My vehicle is doing the exact same thing and I don't want to spend my money on this if it isn't the solution.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
Blakearold
Aug 27, 2015 12:37 PM
joedaddy1
Jul 28, 2015 02:58 PM
RedBaronK
Jul 27, 2015 06:25 PM
driftsucky
Jul 15, 2015 12:38 PM
