buying rims! would this fit?
I have a 2008 infiniti g35x. I am looking to purchase a set of rims with the following specs:
Offset: 30
Rim Material: Alloy
Number of Bolts: 5
Rim Width: 9
Bolt Pattern: 5x114.3
Rim Diameter: 19
Will these fit?!
Offset: 30
Rim Material: Alloy
Number of Bolts: 5
Rim Width: 9
Rim Diameter: 19
Will these fit?!
Your OEM wheels should be 7.5" w/ +45 offset.
Here's a good wheel calculator
http://www.myg37.com/forums/tire_rim_calculator.php
Entering the oem & new figures your new wheels will be 34mm out from where you are now.
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
