How often do you need to refill the coolant reservoir?
Discussion about the 2nd Generation G35 Sedan 2007 - 08
May 30, 2013 | 03:50 PM
vqsmile
Oct 2010
SF bayarea (925)
Quote:
Originally Posted by
stockae92
Dealer said lose hose clamp, lets see if that will fix the leak
Most likely it will; usually it is the little things.
vqsmile
Find all posts by vqsmile
FS:
CA / 2005 G35 Coupe / Ivory Pearl / 5AT /
MrIP35
11:13 PM
What are the symptoms of BHG?
BradMD_96
09:31 AM
Washer line/pump issues
blueslatebenny
01:39 PM
Transmission cooler HELP needed
Usman Ali
06:59 AM
FS:
NEW OEM radiator drain/bleeder gaskets
AuAltima3.5
Cooling
10:46 AM
Tags
2004
2007
check
coolant
fill
g35
infiniti
infinity
leak
refill
replace
reservoir
resevoir
resivor
sedan
top
Back to Subforum
View Next Unread
Getting new wheels-input or feedback/TSW
04:38 PM
