Washer line/pump issues
Old Sep 23, 2015 | 11:49 AM
blueslatebenny's Avatar
Over the summer my washers have stopped working. It seemed to be rather sudden. Sprayer nozzle doesn't work on the drivers side, and on the passenger side, fluid shoots mostly onto the roof and upper windshielf. With winter coming, I need it addressed; dealer quoted me $230 to replace the whole system.
Is this likely a pump issue or a clogged lines issue? This is a system I'm not familiar with so I don't even know where the pump is located - next to the reservoir behind the bumper, I imagine? Pumps are really cheap (~$15) on Rock Auto. Anyone else ever have this problem?
Old Sep 23, 2015 | 01:33 PM
beto4632's Avatar
Its the pump i had the same issue all of a sudden it was not spraying what so ever even with the tank full. Replaced the pump and it works also cleaned out the spray heads with CLR to get those things unclogged
Yes the pump is located on the passenger side behind the wheel cover most likely have to remove your bumper
Old Sep 23, 2015 | 01:39 PM
Thank you very much. I'm glad it's an easy, cheap fix.
G35Rican
Jul 31, 2024 01:37 AM
cmesidewayz
Sep 29, 2015 09:28 PM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
itschuckster
Jul 25, 2015 08:07 AM
