Help Help Flooding Issue
Old Jun 12, 2013 | 04:41 PM
1classyg35's Avatar
Ive scoped around to try and figure this problem out but no one has a solution. My rear floor on the driver's side has a ouddle of water under the rug. I'm assuming this happened after a hard rain i had last week. Has this happen to anyone else? Is there a solution to this issue? Any help will be appreciated.
Old Jun 12, 2013 | 08:34 PM
vqsmile's Avatar
Sounds like you got a leak somewhere. It's not ecxactly rocket science, since the stock car is usually pretty water tight, look into any posibilities that there could be a leak coming from the adjoining door somewhere, like behind the interior panel...was there speaker work, window replacement, or body work done on it? Is the moon roof leaking? Did a window get left down accidentally?
Old Jun 12, 2013 | 08:42 PM
1classyg35's Avatar
Thanks for the response. Everything was closed up no signs of leakage anywhere else. I'm hearing this happens in the Gs in other threads, but no solid solution. I'm hearing it can be a sunroof drain that might be blocked, so the water is routing itself back in the car?
Old Jun 12, 2013 | 08:50 PM
vqsmile's Avatar
I guess that's theoretically possible. Sorry, but I haven't got any direct experience with it though, so I can't offer any particulars. Perhaps locating the drain tube (???) might be a first step.
Old Jun 14, 2013 | 04:00 PM
NeverEnough02's Avatar
Interesting... Open your passanger side door and look at the rubber trim. On mine it looks like it folded down on the top of the door at some point. Now it is permanetly folded down. Mine does not leak but as it wears more, I am sure it will.
G35Rican
Jul 31, 2024 01:37 AM
cmesidewayz
Sep 29, 2015 09:28 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
