Sunroof / Moonroof Stuck
Old Jun 5, 2013 | 05:19 PM
namanc6's Avatar
so i need a little help here guys. my sunroof is stuck open in the tilt position. im down here in san antonio and we're gonna be expecting a lot more rain. i need some help on either fixing this myself or what kind of repair shop would be able to fix it or at least get it closed for me. Thanks in advance.
Old Jun 5, 2013 | 09:54 PM
aktif8's Avatar
You can likely fix it, but do need to drop the front of the headliner.its pretty easy. There's a diy for it out there; I don't have the link, but it should be easily google-able.
Old Jun 5, 2013 | 10:17 PM
vqsmile's Avatar
First, you could try this: https://g35driver.com/forums/search....rchid=14639810
Then this: https://g35driver.com/forums/v36-diy...all-v36-s.html
Good luck.
Old Jun 6, 2013 | 07:23 PM
namanc6's Avatar
thank you guys so much. the last link looks like it's something i can follow. im used to opening and fixing macs, but never tried anything on the interior of my cars. so ill try this when im off from both of my jobs this coming tuesday. wish me luck guys.
Old Jun 7, 2013 | 09:47 AM
aquabat0587's Avatar
I had this same exact issue a few weeks ago. The screws holding the motor assembly in place had backed their way out. I removed the dome light assembly and I was able to screw the screws back in. Works like a charm now.
Old Jun 7, 2013 | 10:49 AM
namanc6's Avatar
Awesome. So did you have to go through all the steps of removing the headliner or is there an easier way? B/c if there is without breaking anything, I'm all for the easier way. Thanks.
Old Jun 7, 2013 | 01:42 PM
Sponger's Avatar
6MT Brembo Coupe
Just remove the A pillars, visors, and door molding. Disconnect the map lights and sunroof switch. Pull down the front of the headliner to get access to the motor and 10mm nuts around the moonroof. Chances are the nuts have worked themselves loose. Re-tighten with Loc-Tite and you should be good.
Old Jun 11, 2013 | 11:41 AM
namanc6's Avatar
thanks for all the help guys. so there was 1 screw that came completely out, and 2 others that were very close to falling out. i tightened everything back up. no the gear grabs the cables. there is still an issue, though. it will only go into the tilted position or halfway open position. i was able to "close" it by timing the transition from halfway open to tilt. in the transition it will actually close. that's when i hit the switch to reopen the roof and it pauses the roof in place. any info why it won't close all the way and stay closed? or why it won't open all the way?
Old Jun 16, 2013 | 12:35 PM
shahzad.shakir's Avatar
I'm having issues with my moonroof not closing from the tilt position. I dropped the ceiling and tightened all the bolts with no luck. I took videos of the issue and pasted links below. Can someone let me know if the problem seems to be the motor? Thanks!
Video Num 1 (general overview): http://sdrv.ms/17e7BkU
Video Num 2 (possible issue?): http://sdrv.ms/17e7yFK
Dallsinghjr1
Sep 17, 2023 11:25 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
