Reflash to solve abrupt throttle?
Old Jul 28, 2013 | 05:01 PM
davrax's Avatar
I've seen some other forums where the 2007 sedan's 'abrupt' throttle can be solved with a reflash. Is that something I can DIY? Or is that a dealer thing? G35S AT.
Thanks!
Old Jul 28, 2013 | 05:15 PM
davrax's Avatar
I found this: http://www.nicoclub.com/archives/g35...-learning.html
I believe the last process is what needs to happen, am I correct?
Old Jul 28, 2013 | 08:23 PM
mikeb2's Avatar
When I first got my '07 G35, I had trouble adjusting to the gas pedal and had found that there was a software "fix". My suggestion would be to drive your car for a while to see if you can adjust yourself to the touchy gas pedal. The issue is that once the TSB is done, it can not be reversed. So, if you get it done and then find the pedal to "squishy" for your liking, too bad.
After a while, I did get used to the pedal and only occasionally will pull an unintentional hole-shot at a light.
Mike
Freeman186
Sep 6, 2023 10:07 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
Joe Gargano
Sep 18, 2015 11:17 AM
