Door Pull Bezel Rubbery Paint Peeling Scratched - Replacement Parts
Old Oct 12, 2013 | 06:25 PM
RyanBlace's Avatar
Hi,
I've seen a lot of threads about the steering wheel rubbery stuff coming off. But, there are not too many (recent) threads on the door bezels.
http://orderinfinitiparts.com/ has then for $35 each.
Part Number
80960JK60A (body hardware, front door, interior trim, switch bezel graphite Right)
80961JK60A (body hardware, front door, interior trim, switch bezel graphite Left)
Make sure you pay attention to the correct color.
It takes about 10 minutes to switch them out. I recommend the "5 Piece Auto Trim and Molding Tool Set" from Harbor Freight.
I had to pay the "stupid tax" for failing to have the dealer replace them under warranty when they replaced the steering wheel trim. If you are in the same boat, at least you don't have to spend a bunch of time searching.
Thanks,
Ryan
Attached Thumbnails Door Pull Bezel Rubbery Paint Peeling Scratched - Replacement Parts-bezels.jpg
Old Oct 12, 2013 | 08:53 PM
vqsmile's Avatar
The last digit in the part number is the color code, so different color trims should have different (unique) part numbers. Therefore, you should never have to worry about ordering the wrong color as long as you got the right part number.
The left or right side is determined by the last digit in the first number group ( 0 = right or passenger side, 1 = left or driver side)
BTW, all of those part numbers, including those for different colors have been posted before in those other (non-recent) threads, but just for good measure, I will post them here too.
80960-JK60A (body hardware, front door, interior trim, switch bezel Graphite Right)
80961-JK60A (body hardware, front door, interior trim, switch bezel Graphite Left)
80960-JK60B (body hardware, front door, interior trim, switch bezel Stone Right)
80961-JK60B (body hardware, front door, interior trim, switch bezel Stone Left)
80960-JK600 (body hardware, front door, interior trim, switch bezel Wheat Right)
80961-JK600 (body hardware, front door, interior trim, switch bezel Wheat Left)
(Graphite = black, Stone = gray, Wheat = beige)
Edit: Thought I'd add the rears too:
82960-JK60A (body hardware, rear door, interior trim, switch bezel Graphite Right)
82961-JK60A (body hardware, rear door, interior trim, switch bezel Graphite Left)
82960-JK60B (body hardware, rear door, interior trim, switch bezel Stone Right)
82961-JK60B (body hardware, rear door, interior trim, switch bezel Stone Left)
82960-JK600 (body hardware, rear door, interior trim, switch bezel Wheat Right)
82961-JK600 (body hardware, rear door, interior trim, switch bezel Wheat Left)
Old Oct 12, 2013 | 10:27 PM
Triton3.5's Avatar
Thanks for this info VQ,, i have to get these on my driver side and prolly pass. front door also.
Old Jun 8, 2016 | 05:23 PM
cteas56's Avatar
Steering Wheel Plastic
Hi All,
Thank you so much for the links. I am having trouble finding the parts for the steering wheel. Does anyone know where I can find them? What they are called? Part No.? I know this post is old, but I would really like to find this. I found the entire steering wheel for over $900. It is an 8 year old car. No thanks. I would like to thank you guys in advance for just reading my post.
Sincerely,
Charles
Old Jun 8, 2016 | 06:20 PM
vqsmile's Avatar
Originally Posted by cteas56
Hi All,
Sincerely,
Charles
Charles, price and availability may have certainly changed a bit over the years, but you can go through these old threads and read up on a lot of the info you're seeking:
https://g35driver.com/forums/g35-sed...ent-diy-2.html (see post #56 in particular)
https://g35driver.com/forums/g35-sed...placement.html
https://g35driver.com/forums/g35-sed...-chipping.html
Just remember that it really matters to get the right one due to color and trim level compatibility concerns. Also, a cheaper route that lot of people use is to just remove them, strip them, and then repaint with a better paint.
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
emorehs
Jul 17, 2015 09:45 AM
