Transmission Oil - Matic S or Something Else?
Old Oct 19, 2013 | 09:59 AM
gary c's Avatar
Having the same question you do I looked for AMSOIL synthetic trans fluid only to find they recommend using Nissan OE fluids in our transmissions. AMSOIL makes the finest synthetic fluids on the planet so I gotta go with their recommendations!
Gary
Old Oct 19, 2013 | 12:01 PM
joesmithf1's Avatar
Originally Posted by Q8y_drifter
Make sure the car is level when draining and filling the diff.
Fill in as much tranny oil as you drained. Then go through the gears and check the level with the dipstick to make sure it's good.
thanks again, Everyone! Followed all of your recommendations and advice and got everything changed out last night. Took about 3 hours, since i wanted to take the time to do it right. I also flushed the radiator fluid. Can't wait to take it for a spin today!
Old Oct 21, 2013 | 12:22 PM
coffeysm's Avatar
Make sure you carry some extra coolant with you and check the level periodically. I replaced mine a couple of weeks ago. Got nice hot air at idle and no overheating problems, but there must have still been a lot of air still trapped in the system. I had to fill up the reservoir to the MAX line about three times since then. I don't have any leaks either I checked all around, lol.
I'm also about to change my ATF fluid and went with Idemitsu Type J matches the exact specs of Nissan/Infiniti. I also read that they work closely with Nissan/Infiniti when developing their fluids. It's about 7.5-12 dollars online, but I got a sweet deal on eBay 10 quarts for about 50 bucks.
http://www.ilacorp.biz/transmission_fluid.htm
Old Oct 22, 2013 | 09:47 AM
yosip1115's Avatar
Does anyone have experience dropping the AT pan? There is a $20 filter available that us supposedly up in there... Has anyone every done this job? Is there a point? 136k miles here
Old Oct 22, 2013 | 03:41 PM
coffeysm's Avatar
I haven't done it myself it's one of those do I really want to mess with lists. Basically, from what I have read people pull it off to clean the two magnets and any possible sludge residing in the pan.
Old Oct 22, 2013 | 04:42 PM
VQdriver's Avatar
Originally Posted by kpowe1
Well I went in the opposite direction and use castrol ATF for a drain and refill, twice and that was about 20,000 miles ago and I haven't had any problems yet. Its about time that I do it again and I have 222,000 on my trans
Do you remember if you used Castrol Transmax Import Multi Vehicle? I've seen Youtube vids of Eric the car guy using Valvoline ATF on Toyota trucks without problems. I'm about to do an ES330 and Maxima with each calling for Toyota ATF type 4 and Nissan Matic J respectively. The Castrol Transmax Import Multi Vehicle supposedly satisfies those specs and I'm more confident in Castrol products than Valvoline stuff. I think the only transmissions to worry about were the earlier 2000 Honda transmissions which were known to grenade...I could be generalizing though
Old Feb 28, 2016 | 06:59 PM
abrecos's Avatar
I found idemitsu ATF J type on Ebay for 66.99$ for 12 quarts,that is 5.58$ for one quart,cant beat that deal and i think i going to do drain and refill method on my 2008 G35 sedan transmission.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
MrIP35
Oct 25, 2015 11:13 PM
alessandro
Oct 8, 2015 09:29 AM
TNRocker
Sep 21, 2015 08:36 AM
