Dang Heated O2 Sensor
Old Oct 17, 2013 | 01:34 PM
ChinkyChoy's Avatar
Unhappy Dang Heated O2 Sensor
So my G finally came up with a service engine soon light
took it to auto zone and the code was for a heated O2 Sensor Bank 1 sensor 1
I believe this is correct because i ve been experiencing a pretty drastic drop in MPG
Course of action would be to take it in to the stealership and see how badly they want to give it to me
Anyone have any input on this? go to the dealership? do it myself? take it to the nissan dealership?
Thanks!
Old Oct 17, 2013 | 01:39 PM
Urbanengineer's Avatar
Your gonna troll me for this, but when I threw this code I threw seafoam cleaner in the fuel and it cleaned up after a full cycle. Code went away Gas mileage went positive. Your choice. Ultimately stealership can price it, indy shop should fix it thou much cheaper.
Old Oct 17, 2013 | 03:27 PM
ChinkyChoy's Avatar
yeah i dunno about the sea foaming thing.
I went to a firestone on base they quoted me $364 for the parts and labor i m still waiting on the dealership probably going to be up around $500
Old Oct 17, 2013 | 03:55 PM
It just cleans the fuel track. Your not putting it in the crank case .
Old Oct 29, 2013 | 09:52 PM
Duk's Avatar
Duk
I had that check engine light for a while (same code). I just reset it to make the light go away, as i heard it can be triggered by my old battery. but it came back after few hundred miles. i reset it again...same thing. So I finally just got that 02 sensor replaced at a indy shop. I believe i paid between $350- $400 (parts and labor). It may be placebo, but performance seems to have improved- just feels more solid. idk. but i will have to get back on the mpg improvement. Dealer quoted me around $550 parts n labor.
Old Oct 29, 2013 | 11:45 PM
Shawno72's Avatar
How many miles do you have?
Old Oct 30, 2013 | 09:14 AM
ChinkyChoy's Avatar
Sounds about right dealer is at almost $600 while the firestone on base said $364. maybe i can convince them to come down or say its warranty work
about 64k give or take 1k
Old Oct 30, 2013 | 10:54 AM
Shawno72's Avatar
Let us know if your gas mileage improves
Old Oct 30, 2013 | 01:57 PM
Duk's Avatar
Duk
I have about 45K miles. Will report back about the mpg once empty.
Old Oct 30, 2013 | 02:00 PM
Duk's Avatar
Duk
I tried the warranty route. but even with close to 40k mi warranty ( I have 45k ), they didnt budge. It's an emission issue. maybe you'll have better luck. worth a shot.
Old Oct 30, 2013 | 02:13 PM
rhampsterwha2's Avatar
recently replaced my #1 no way I was going to take it to the dealer for a O2 sensor, just get another sensor from Autozone/Advanced Auto ($115) and replace it yourself
its pretty easy to get to even though its in a tight place
Old Oct 30, 2013 | 02:18 PM
ChinkyChoy's Avatar
dont you need that special socket or w/e to get the sensor out?
did autozone have it for rent? also did you get an OEM sensor?
Old Oct 30, 2013 | 02:21 PM
Bosh OE type replacement
no dont "need" the special socket its still doable without it just hit it with some PB blaster a few times prior to trying to remove it with your wrenches
Old Oct 30, 2013 | 02:30 PM
that sensor is also called 'Air fuel ratio sensor' its the upstream not the one that fits in the cat
Old Oct 30, 2013 | 03:57 PM
ChinkyChoy's Avatar
sounds good i ll give it a try when i get back from TDY
