Clutch / Brake Fluid compartment
Old Nov 9, 2013 | 01:13 AM
Gig103's Avatar
Hi all,
I opened up the brake fluid compartment on my wife's 2007 G35 because of a mushy pedal, and the brake fluid looks at a proper level. But the smaller one is for the clutch, right? Because it shows no fluid at all! What do I need to do? Should I just refill it, and if so with what? It's bone dry, will I need to bleed it or just add fluid and pump the clutch?
Could it be indicative of a serious problem that I need immediate attention on, or do I just refill it and keep an eye on it?
Edit: I had the transmission flushed at 60k (5k ago), but I thought that was a different thing - just wanted to mention it anyway in case it helps.
Thanks for the help!
Attached Thumbnails Clutch / Brake Fluid compartment-imag0596.jpg
Old Nov 9, 2013 | 03:02 AM
dofu's Avatar
20 Year Member
If that's for your clutch, it needs to be filled with brake fluid. You might want to get it checked too because that is not normal. A transmission fluid flush is completely different.
Old Nov 9, 2013 | 03:15 AM
Gig103's Avatar
Thanks dofu. Do the folks here have a preferred brand or any old DOT-3? Considering it's the weekend I want to fill it and keep a close eye on it. If I fill it and pump the clutch, is that sufficient to circulate the fluid or do I need to open the bleed valve underneath as well since it is pretty dry at the moment?
Old Nov 9, 2013 | 10:55 PM
Triton3.5's Avatar
You might have gotten lucky and there was just enough in the clutch master cylinder to still work, without getting air in the line... I would just add and see how it works, cause it sounds like your still driving the car, so it must still disengage the clutch good enough to shift the car. otherwise it would be wise to flush, or exchange the fluid, ie. bleed the whole system, brake fluid does not last forever...... both the clutch and the brake systems....
Old Nov 9, 2013 | 11:15 PM
vqsmile's Avatar
I'd be worried about where all that fluid went. Is there a leak somewhere in the clutch hydraulics?
Old Nov 11, 2013 | 12:41 AM
Gig103's Avatar
Thanks everyone. I added the fluid yesterday, pumped the clutch pedal a lot, and then took the car on a test drive to the store and back without a loss of fluid in the reservoir. I just checked again after the car sat, still no loss. The real test will be when my wife gets home from work tomorrow.
Danielek
May 1, 2022 01:28 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
yosip1115
Sep 9, 2015 03:30 PM
