steering too sensitive at highway speeds
Old Dec 27, 2013 | 11:17 AM
g35xdriver's Avatar
g35x
after a 60K service I've noticed that my steering is hyper sensitive, such that, at highway speeds, the car feels uncomfortable to drive.
[prior to the service there was some rubbing sounds at highway speeds from the front, but no vibration/tracking problems. dealer mentioned the tire wear was low, and showing some cupping.]
so, new tires, alignment, power steering and brake fluid flush later (at an independent shop), and the issue has improved but not really gone away. It still feels like I'm getting maximum power assist to the steering at highway speeds.
any idea what to look for, what might be the cause. anyone else with similar issues out there?
thanks in advance.
Old Dec 27, 2013 | 09:34 PM
blnewt's Avatar
Do you have your alignment readings? Sounds like you might need a bit of toe-in or if you're lowered your caster might be out of spec.
Old Dec 28, 2013 | 06:53 PM
vqsmile's Avatar
^^ Agreed.
Being slightly toe'd OUT (i.e. negative), or even just right at neutral (zero) toe can cause a very touchy steering feel as described. Great if you're racing, but annoying for a DD.
Other than that, I don't recall the V36 having speed sensitive steering, but I have seen on other cars that actually do, that it's possible for the low speed (high-assist) mode to be stuck on all the time, thereby giving an inordinate amount of assist even at high speeds.
Old Dec 30, 2013 | 07:53 AM
g35xdriver's Avatar
g35x
thanks for the replies.
on the alignment, only the back was out of alignment, and the shop adjusted the toe-in for the front. it's driveable now, but stills feels too touchy to me. maybe it's in my head.
magnetism80
Feb 1, 2019 10:00 AM
G35xdriver04
Nov 7, 2015 08:31 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
